Were or how can I pull logs ?
ciscomdsmagic
For Nexus 3132Q-V switches, if I wanted to check logs or something happened before, where or how can I do that? Thanks!
nazimkha
Level 4
Level 4
Did you configure a syslog server. If the switch has not rebooted and there was enough buffer you can always check the 'show log' output to see the logging messages
Thanks! two follow-ups:
Does that mean logs would not be persistent after reboot the switch?
How do I set up syslog? I don't see it in docs.
Yes. Unless it is saved to some server
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/system_mgmt/503_U3_1/b_Cisco_n3k_System_Mgmt_Config_503_U3_1/b_Cisco_n3k_System_Mgmt_Config_503_U3_1_chapter_01010.html#d16541e451a1635
