03-02-2012 11:15 AM
For uplink port channels in 1000v, I am seeing mac-pinning chosen in many best practice guides when used in Cisco UCS. However, I have not been able to find any documentation why mac-pinning is infact better choice than VPC-HM for deploying 1000v within VMware vSphere on UCS.
Can someone enlighten me on this?
Thanks.
Brian
03-02-2012 11:23 AM
Mac-pinning is a form of VPC-HM.
Since UCS doesn't support host-based port channels (yet), the only other option is mac pinning. Mac pinning is simple and solid. I recommend MAC pinning to most people unless they severly requires the aggregate bandwidth of a port channel - assuming the Host can support it.
Robert
03-02-2012 11:30 AM
Hello Brian. vPC-HM (host mode) is how the Nexus 1000v does the port-channeling. With this vPC-HM there are 3 options on how the port-channeling is done. This is configured on the port-profile of type "Ethernet" that is used by the physical NICs on your ESX/ESXi servers. The command used for this is:
channel-group auto mode active | passive| on [mac-pinning or cdp]
With the UCS blades interfaces pinned to a particular FI (i.e. vnic0 to Fabric-A and vnic1 to Fabric-B) and since the FI are not capable to have vPC for the blade servers, that leaves the option of either mac-pinning or cdp. Since mac-pinning is the recommended between the 2 options, that is why you see all deployments of UCS with N1KV today using mac-pinning. Hope this helps.
Cuong
03-02-2012 12:14 PM
Thank you guys. I am trying to see why cdp approach is not recommended. Is there anything that makes it undesirable? I understand this would require a CDP enabled switch and thus not an option when you don't have cdp enabled upstream switch.
Thanks again.
03-02-2012 12:19 PM
As Robert commented, it's quite simple and pretty solid. CDP does the exact same thing as mac-pinning but again, based upon mac-address vs. upstream switch using cdp. Since not everyone has CDP, mac-pinning is preferred to make things simpler and has a lot more solid track right now.
03-05-2012 11:11 AM
Brian
05-31-2012 04:27 AM
hello,
can i configure mac pinning and static pinning together?
In lab we have configured vPC-HM with static pinning to force the fabric used for a service and it works ok, but static pinning does not work in lab with mac pinning..
Francisco
