Hello all,We are preparing to upgrade our fabric from 3.2 to 4.2. In reading the official Cisco guide, in the section Important Notes on Upgrading the Cisco APIC and the Switch Software , I saw this bullet point (emphasis added) : Beginning with Rele...
view more
Hello,I am new here and seeking some comments now. We are deploying 2xC9500-48Y4C-A as core switches(running stackwise), 2 C93180(nexus) and several C9300 (layer2). Can someone recommend what firmware should we use? Client wants to have 1...
view more
I'm trying to get a JSON/XML output from APIC showing all the EPGs associated to a VPC pair and the external VLAN Mappings. I've been able to find it in the GUI, but can't seem to export it in any usable form. I need to copy the configuration ...
view more
I would like to now if there is a list/compatibility matrix what ACI versions are compatible with which vDS versions.For example - I run ACI 3.2.5 with vSphere 6.7 and vDS 6.0. Now I'd like to upgrade the ACI fabric to version 4.2.6[h].According to the&nb...
view more
Hello,Our Datacenter deploys a topology which is almost alike a Spine and Leaf VXLAN-enabled design. The Spines are N3K-C3164Q and leafs are N9K-C9396PX. Routerports connect the 9396 to the VXLAN fabric. There is an anycast-rp configured on the C3164...
view more
