We have intersite link between two pairs of Cisco Nexus 5672 in our DC. We need your guidance to confirm is it possible to apply netflow and export it to solarwinds on that layer2 link so that we can see what data is traversing on this layer 2 link and wh...
view more
after the seeing the CSCvs78207 advisory we need to upgrade from 11.3 to 11.5 We current run it on Windows server 2016 I have read through the upgrade document and it talks about having to reindex the PMDB by using the ReindexAlarmsCu...
view more
Hello guys.I was wondering if someone could help me to understand better what is the use case for the EPG Destination Type when you are configuring an Span Destination Group on ACI.I dont have it clear and also the source IP/Prefix should it be any addres...
view more
Hi,I have cisco 6513 Core switch, having module WS-X6816-10G-2T / WS-X6816-10GE(baseboard) I need 10G modules for it. Will X2-10GB-LR be compatible with it? also on the Access Switch side I will use Cisco SFP-10G-LR, will it work ok with X2-10G-LR?@...
view more
