PLEASE NOTE: The Kinetic developer discussions are moving to the main Kinetic board.
You should get a more active community response there.
590
Steve Zhang
How to send data to IBM Watson IoT or MS Azure IoT Hub with Kinetic DCM?
By default, Kinetic data is available in the "Internal Broker", which is a RabbitMQ broker. Each organization has it own exchange associated with the Internal Broker. For consuming Data from the Internal Broker, please refer to https://developer.cisco.com/docs/kinetic/#!consuming-data-from-the-internal-broker.
IBM Watson IoT and MS Azure IoT Hub are also the supported Data Destination. For details, please refer to:
Send Data to IBM Watson IoT: https://developer.cisco.com/docs/kinetic/#!ibm-watson-iot
Send Data to MS Azure IoT Hub: https://developer.cisco.com/docs/kinetic/#!microsoft-azure-iot-hub
0 REPLIES 0
Content for Community-Ad
