Highlighted
Beginner
Eclipse Krikkit Rule Engine
i am trying out Krikkit rule engine with C API. I am trying to understand where i will be adding the more business rules which also involves some complex calculations combined with arithmetic and logical computation for some parameters (10 properties).I am trying out to integrate with modbus protocol ( C code) and the parameter registers address generates output in JSON format.I too want to know how do i read those parameters from JSON data ,apply some rule using Krikkit and stream data to local dashboard that is connected to edge device.
Lakshmi
0 REPLIES 0
