05-05-2022 10:50 PM
Hi Guys,
we have installed CML2 but we are getting only 2 nodes (unmanaged switch, external connector). Can someone please suggest how to add all nodes like IOSvl2 , IOSV, Desktop, etc.
Thank you!
Solved! Go to Solution.
05-05-2022 11:39 PM
Refer installation guide, you need to have ISO image which has all images.
05-05-2022 11:39 PM
05-08-2022 08:37 PM
Thank you Balaji for response. So do we need to uninstall CML and again need to re-Install after adding ISO images in path or is there any other way to add ISO images on installed CML directly. Looking forward for your valuable response.
Thank you!
05-05-2022 11:57 PM
Hello @akshayj2097 for CML Personal you can work directly with the support team https://learningnetwork.cisco.com/s/topic/0TO3i00000094ZjGAI/cisco-modeling-labs-personal-community
