Cisco Modelling Lab Nodes
akshayj2097
Hi Guys,
we have installed CML2 but we are getting only 2 nodes (unmanaged switch, external connector). Can someone please suggest how to add all nodes like IOSvl2 , IOSV, Desktop, etc.
Thank you!
balaji.bandi
balaji.bandi
Refer installation guide, you need to have ISO image which has all images.
https://www.cisco.com/c/en/us/td/docs/cloud_services/cisco_modeling_labs/v200/quick/start/b_cml_quick_start_2-0/m_deploy_and_configure.html
BB
Thank you Balaji for response. So do we need to uninstall CML and again need to re-Install after adding ISO images in path or is there any other way to add ISO images on installed CML directly. Looking forward for your valuable response.
Thank you!
Hello @akshayj2097 for CML Personal you can work directly with the support team https://learningnetwork.cisco.com/s/topic/0TO3i00000094ZjGAI/cisco-modeling-labs-personal-community
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
