how to set the dial internal extension directly in AA TCL script
Kyaw Kyaw San
Dear all,
I  am using CME with aa-bcd service.But I would like to dial the internal extension directly without press '1' .But CISCO default script don't have that features.I am very glad if anyone help to edit this script.
In CISCO default script,to dial the internal extension with press '1' and after we can dial the internal extension.
17 Replies 17
yawming
Can you please share the script you are using ?
Please kindly check the CISCO default TCL script file.
This is command file run is CISCO router
application
service aa-test flash:app-b-acd-aa-3.0.0.5.tcl
  paramspace english index 1
  param max-time-vm-retry 2
  param max-time-call-retry 20
  param voice-mail 5003
  paramspace english language en
  param aa-pilot 6000
  param number-of-hunt-grps 1
  param dial-by-extension-option 1
  param handoff-string aa-test
  param welcome-prompt _bacd_welcome.au
  paramspace english location flash:
  param call-retry-timer 15
  param service-name queue
  param menu-timeout 5
  param second-greeting-time 30
service queue flash:app-b-acd-3.0.0.5.tcl
  param queue-len 15
  param aa-hunt1 2000
  param operator 0
  param queue-manager-debugs 1
This script has the feature built in. Please refer to this gudie.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/bacd/configuration/guide/cme40tcl.pdf
if [infotag get cfg_avpair_exists dial-by-extension-option] {
set dialByExtension [string trim [infotag get cfg_avpair dial-by-extension-option]]
} else {
set dialByExtension "NONE"
f {$status == "cd_005"} {
set KATIMER(keepTime) [clock seconds]
set optionSelected [infotag get evt_dcdigits]
puts ">>>>>>>>>>>>> return from infotag get evt_dcdigits is : $optionSelected <<<<<<<<<<<<<<<<<<<<<<<<<"
if {$optionSelected == $dialByExtension} {
puts -nonewline "TCL AA: +++ Collect Extension Digits +++"
set retryDigitCollect 1
leg collectdigits leg_incoming PARAM1
media play leg_incoming _bacd_enter_dest.au
fsm setstate CALLTOEXTENSION
Kyaw Kyaw San
If you just want to do :
Reuired Prcedure for incoming call is
The caller dail the PSTN number>>>en_bacd_welcome.au (greeting prompt coming up)>>>>the caller can type the internal extension number directly or  the caller can type the operator number "0" to call the operator.
Then the bacd script is overkill.
You also need to think about if caller didn't enter digit in certain period of time what do you want to handle ? What is the extension digit length ?..etc. There may have existing script somewhere see if I can dig it out. Will update you later.
Dear yawchen,
I got all.thanks you for supporting me.You are awesome.
Glad it works for you !
Dear yawchen,
Thanks again your help.It is possible to edit this tcl script with NOTEPAD++.Because it default righ time is about 30 s and retry count is about 6 time to alreat the operator.I would like to reduce the time to ring time to 5 s and retry call time to 2.I edit in the script but it show error like this.Can u help also.
%CALL_CONTROL-6-APP_NOT_FOUND: Application aa-test in dial-peer 100 not found.  Handing callid 67 to the alternate app .
   set retrycnt 6 -> to set retry count
   set callInfo(alertTime) 30 -> to set ringing time
you can use notepad to edit
Dear yawchen,
I would like to add music on hold file while calling operator .It is possible.
Not with this script. In this script we call ext or operator immediately,  not put caller in queue so no need to MOH.
Dear Yawchen,
So please kindly guide me which is more compatible script for those requirements.Thank you very much!
Dear yawchen,
I would like to put the MOH while dialing the operator.Can you guide me how to do.
