IAC 4.0 Reference Architecture
vhulsey
Can anyone provide a sample reference architecture for IAC 4.0? I'm looking for something that shows integration points with UCS Director and OpenStack, and elaborates on how these cloud platforms are integrated and what functions they server.
Lee Calcote
Participant
Participant
Loren,
Here are the specifics on Cisco IAC 4.0 UCS Director Integration. There's much more material on IAC's support for other cloud platforms should you need it.
Lee
Geevarghese Cheria
Hi Loren,
If you have not gone through this url please have a look. i think it has got some cisco live links which may help you to find the answer.
  Introducing Cisco Intelligent Automation for Cloud 4.0
Thanks and Regards,
Geevarghese
http://blogs.cisco.com/datacenter/introducing-cisco-intelligent-automation-for-cloud-4-0/
Lee Calcote
Participant
Participant
Loren,
Lee
rruckley
Beginner
Beginner
For some reason that link is not available to me.
