How to login IP Phone cisco from cucm with 3rd party program #extentionmobility
vanjavajazz
Hello everyone
I have some trouble with developt extention mobility 3rd party program
The concept is, I wanna login my account that contain my ext from an app (in general login from Ip phone devices)
Then I found this link Sample Apps- Cisco EMAPI
problem that I found by using this code is ssl problem.. then I've succeed passed it using some code
then till now I'm got stuck whis this
heres the codes
package com.cisco.extensionmobility;
import java.io.*;
import java.net.URLEncoder;
import java.io.InputStreamReader;
import java.net.URL;
import java.net.URLConnection;
import javax.net.ssl.HostnameVerifier;
import javax.net.ssl.HttpsURLConnection;
import javax.net.ssl.SSLContext;
import javax.net.ssl.SSLSession;
import javax.net.ssl.TrustManager;
import javax.net.ssl.X509TrustManager;
import java.security.cert.X509Certificate;
public class EMAPISample {
public static void main(String[] args) throws Exception {
  // Create a trust manager that does not validate certificate chains
    TrustManager[] trustAllCerts = new TrustManager[] {new X509TrustManager() {
            public java.security.cert.X509Certificate[] getAcceptedIssuers() {
                return null;
            public void checkClientTrusted(X509Certificate[] certs, String authType) {
            public void checkServerTrusted(X509Certificate[] certs, String authType) {
//To test with insecure connection use the URL as http://cucm-host.com:8080/emservice/EMServiceServlet
    // Install the all-trusting trust manager
    SSLContext sc = SSLContext.getInstance("SSL");
    sc.init(null, trustAllCerts, new java.security.SecureRandom());
    HttpsURLConnection.setDefaultSSLSocketFactory(sc.getSocketFactory());
    // Create all-trusting host name verifier
    HostnameVerifier allHostsValid = new HostnameVerifier() {
        public boolean verify(String hostname, SSLSession session) {
        return true;
    // Install the all-trusting host verifier
    HttpsURLConnection.setDefaultHostnameVerifier(allHostsValid);
    URL url = new URL("https://192.168.10.11:8443/emservice/EMServiceServlet");
//Create a java.net URLConnection object to make the HTTP request
URLConnection conn = url.openConnection();
//setDoOutput=true causes the URLConnection to perform a POST operation
conn.setDoOutput(true);
//The request body will be in HTTP form encoded format
conn.setRequestProperty("Content-Type","application/x-www-form-urlencoded");
//Build a string containing the contents of the E/M API XML request - here 'login'
String EMRequest = "<request><appinfo><appid>operator</appid><appcertificate>operator</appcertificate></appinfo>";
EMRequest += "<login><devicename>SEP000000000003</devicename><userid>ivan</userid><deviceprofile>ivan</deviceprofile>";
EMRequest += "<exclusiveduration><time>60</time></exclusiveduration></login></request>";
//URL encode/escape the request
EMRequest = URLEncoder.encode(EMRequest,"UTF-8");
//Build the complete HTTP form request body
EMRequest = "xml="+EMRequest;
//Create an OutputStreamWriter for the URLConnection object and make the request
OutputStreamWriter writer = new OutputStreamWriter(conn.getOutputStream());
writer.write(EMRequest);
writer.flush();
//Read the response
BufferedReader reader = new BufferedReader(new InputStreamReader(conn.getInputStream()));
//Output the response to the console
String line;
while ((line = reader.readLine()) != null) {
  System.out.println(line);
writer.close();
reader.close();
The result is
Error processing request: null
Is there any solution? Please helpp
I've got stuck for many days with this code
Thank you very much
Geevarghese Cheria
Hi Ivan,
Did you had chance to try out the steps mentioned in this url - EM Proxy service
Request to post if there is any further question related to the topic under Extension Mobility API community.
Thanks and Regards,
Geevarghese
pesnexium
Sorry to be late for answering, but I have just faced the same situtation. After having solved the isssue of certificate, I solved that one by modifying the case of the inside elements <appID>, etc.
I work on this Momont on cisco extension mobility, and try to login user id in the IP phone. when i try to do it on the phone directely it's working.
But when I try to execute my code that I have developed , I receive an error code 0 and I ignore this error.
<respone>
<failure>
<error code ="0"> null </error>
</failure>
</response>
can you please help me I inform you that my code is as follows:  thank you in advance
using System;
using System.Collections.Generic;
using System.Text;
using System.Collections;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Net;
using System.IO;
using System.Configuration;
using System.Net.Configuration;
using System.Xml;
namespace EM_Firmwares
    class EM
      static void Main(string[] args)  {
Login("SEP1CAA07E3743D", "wma", "");
        public static void Login(string device, string userID, string udp ="")
            string TempUrl = string.Empty;
            string Host = ConfigurationManager.AppSettings["192.168.0.110"];
            TempUrl = "http://" + Host + ":8080/emservice/EMServiceServlet";
            ServicePointManager.ServerCertificateValidationCallback += delegate { return true; };
            StringBuilder emRequest = new StringBuilder("");
            HttpWebResponse Response;
            Configuration Config = ConfigurationManager.OpenExeConfiguration(ConfigurationUserLevel.None);
            SettingsSection Section = (SettingsSection)Config.GetSection("system.net/settings");
            Section.HttpWebRequest.UseUnsafeHeaderParsing = true;
            Config.Save();
            HttpWebRequest Request = (HttpWebRequest)WebRequest.Create(TempUrl);
            Request.ProtocolVersion = System.Net.HttpVersion.Version11;
            Request.Timeout = 100000;
            Request.Method = "POST";
            Request.ContentType = "application/x-www-form-urlencoded";
            Request.Accept = "Accept: text/*";
            string emUser = ConfigurationManager.AppSettings["MC"];
            string emPassword = ConfigurationManager.AppSettings["Azopqslm123!"];
            emRequest.Append("xml=<request><appInfo><appID>" + emUser + "</appID><appCertificate>" + emPassword + "</appCertificate></appInfo>");
            emRequest.Append("<login><deviceName>" + device + "</deviceName><userID>" + userID + "</userID>");
            if(udp != ""){emRequest.Append("<deviceProfile>" + udp + "</deviceProfile>");}
            emRequest.Append("<exclusiveDuration><indefinite></indefinite></exclusiveDuration></login></request>");
            Request.ContentLength = (long)emRequest.Length;
            try
                Stream RequestStream = Request.GetRequestStream();
                RequestStream.Write(System.Text.Encoding.ASCII.GetBytes(emRequest.ToString()), 0, emRequest.Length);
                RequestStream.Close();
            catch (WebException x)
                Console.WriteLine("Login Error, " + udp + ", " + device + ", " + userID + ", " + x.Message);
                return;
            string Xml = string.Empty;
            try
                Response = (HttpWebResponse)Request.GetResponse();
                Stream ResponseStream = Response.GetResponseStream();
                StreamReader ReadStream = new StreamReader(ResponseStream, Encoding.UTF8);
                Xml = ReadStream.ReadToEnd();
            catch (WebException x1)
                Console.WriteLine("Login Error, " + udp + ", " + device + ", " + userID + ", " + x1.Message);
                return;
            XmlDocument xdoc = new XmlDocument();
            xdoc.LoadXml(Xml);
            XmlNode node = xdoc.DocumentElement;
            XmlNodeList nodeList  = node.SelectNodes("success");
            if (nodeList.Count == 0)
                nodeList = node.SelectNodes("failure");
                Console.WriteLine("Login Error, " + udp + ", " + device + ", " + userID + ", " + nodeList[0].InnerText);
            else
                Console.WriteLine("Login Success, " + udp + ", " + device + ", " + userID + ",");
        public static string Logout(string device)
            Config.Save();
            emRequest.Append("<logout><deviceName>" + device + "</deviceName>");
            emRequest.Append("</logout></request>");
            try
                Console.WriteLine("Logout Error, "  + device +  ", " + x.Message);
                return "Error";
            string Xml = "";
            try
                Console.WriteLine("Logout Error, "  + device + ", "  + x1.Message);
                return "Error";
            xdoc.LoadXml(Xml);
                Console.WriteLine("Logout Error, "  + device + ", "  + nodeList[0].InnerText);
                return "Error";
            else
                Console.WriteLine("Logout Success, " + device  + ",");
                return "success";
        public static string UserQuery(string device)
            Config.Save();
            emRequest.Append("xml=<query><appInfo><appID>" + emUser + "</appID><appCertificate>" + emPassword + "</appCertificate></appInfo>");
            emRequest.Append("<deviceUserQuery><deviceName>" + device + "</deviceName>");
            emRequest.Append("</deviceUserQuery></query>");
            try
                Console.WriteLine("UserQuery Error, " + device + ", " + x.Message);
                return "Error";
            string Xml = "";
            try
                Console.WriteLine("UserQuery Error, " + device + ", " + x1.Message);
                return "Error";
            xdoc.LoadXml(Xml);
            XmlNodeList nodeList = xdoc.GetElementsByTagName("userID");
                nodeList = xdoc.GetElementsByTagName("none");
                if (nodeList.Count != 0)
                    string result = "UserQuery Success, " + device + ", " + "No user logged in (No Error)";
                    Console.WriteLine(result);
                    return result;
                else
                    string error = "UserQuery Error, " + device + ", " + nodeList[0].InnerText.TrimEnd('\r', '\n');
                    Console.WriteLine(error);
                    return error;
            else
                Console.WriteLine("UserQuery Success, " + device + ", " + nodeList[0].InnerText.TrimEnd('\r', '\n'));
                return nodeList[0].InnerText;
        public static string DeviceQuery(string userID)
            Config.Save();
            emRequest.Append("<userDevicesQuery><userID>" + userID + "</userID>");
            emRequest.Append("</userDevicesQuery></query>");
            try
                Console.WriteLine("DeviceQuery Error, " + userID + ", " + x.Message);
                return "Error";
            string Xml = "";
            try
                Console.WriteLine("DeviceQuery Error, " + userID + ", " + x1.Message);
                return "Error";
            xdoc.LoadXml(Xml);
            XmlNodeList nodeList = xdoc.GetElementsByTagName("deviceName");
                string error = "UserQuery Error, " + userID + ", " + nodeList[0].InnerText.TrimEnd('\r', '\n');
                return error;
            else
                Console.WriteLine("DeviceQuery Success, " + userID + ", " + nodeList[0].InnerText.TrimEnd('\r', '\n'));
        public static string DeviceProfileQuery(string userID)
            Config.Save();
            emRequest.Append("<deviceProfileQuery><userID>" + userID + "</userID>");
            emRequest.Append("</deviceProfileQuery></query>");
            try
                Console.WriteLine("UDPQuery Error, " + userID + ", " + x.Message);
                return "Error";
            string Xml = "";
            try
                Console.WriteLine("UDPQuery Error, " + userID + ", " + x1.Message);
                return "Error";
            xdoc.LoadXml(Xml);
            XmlNodeList nodeList = xdoc.GetElementsByTagName("deviceProfileName");
                return error;
            else
                Console.WriteLine("UDPQuery Success, " + userID + ", " + nodeList[0].InnerText.TrimEnd('\r', '\n'));
cordially
Massinissa.
