Missed link in Cisco DevNet Lab
LamoSS
Community Member
Hello!
I'm going through Cisco DevNet Labs and at the moment I'm on this step https://developer.cisco.com/learning/tracks/containers/containers-mgmt/containers-deploy-to-k8s/step/1
Here is point:
Powershell on Windows 10
  scp developer@198.18.133.48:"'/home/developer/.kube/config'" $HOME\.kube\config
But if I will execute this command, I will get error message "protocol error: filename does not match request"
Why? It is mistake inside Lab? Or should I run something before executing?
Thank you,
Best regards,
Roman
Seb Rupik
Hi there,
I believe you only need the single quotes if you are dealing with spaces in the filepath/ file name. Try:
scp developer@198.18.133.48:"/home/developer/.kube/config" $HOME\.kube\config
Arguably since there are no spaces in the path the double quotes could be removed:
scp developer@198.18.133.48:/home/developer/.kube/config $HOME\.kube\config
cheers,
Seb.
