NSO Webui ciphers configuration problem via ncs.conf
jabouche
Hi, I wanted to configure the NSO ncs.conf webui ciphers list (colon delimited list of values provided on the man page for ncs.conf).  While I could get the equivalent full list the man page provided as equivalent to <ciphers>DEFAULT</ciphers> running, I could not connect to it with the latest version of Google Chrome.  If I remove the settings or just leave DEFAULT, I can connect to the NSO Webui with HTTPS.  I've tried several versions from 5.4.5.2 to 5.7 and still see the problem. Has anyone used this ncs.conf value and if so, can you tell me what I'm missing?  Note that I knew the list was getting parsed as it made me remove 3 from the list indicated as DEFAULT to start NSO as "not supported".
Jim
0 Replies 0
