06-08-2018 01:57 AM - edited 06-04-2019 02:39 AM
I reserved a lab but can't VPN to the lab. Tried both OSX and Windows and getting the following error:
Log from Mac (AnyConnect 4.5):
The secure gateway has rejected the connection attempt. A new connection attempt to the same or another secure gateway is needed, which requires re-authentication.
The following message was received from the secure gateway: No assigned address
Log from Windows (AnyConnect 4.4):
6/8/2018
6:51:28 PM Contacting 128.107.93.228:20340.
6:51:35 PM User credentials entered.
6:51:37 PM Establishing VPN session...
6:51:37 PM The AnyConnect Downloader is performing update checks...
6:51:37 PM Checking for profile updates...
6:51:37 PM Checking for product updates...
6:51:37 PM Checking for customization updates...
6:51:37 PM Performing any required updates...
6:51:37 PM The AnyConnect Downloader updates have been completed.
6:51:38 PM Establishing VPN session...
6:51:38 PM Establishing VPN - Initiating connection...
6:51:40 PM Disconnect in progress, please wait...
6:51:40 PM The secure gateway has rejected the connection attempt. A new connection attempt to the same or another secure gateway is needed, which requires re-authentication.
6:51:40 PM AnyConnect was not able to establish a connection to the specified secure gateway. Please try connecting again.
6:51:41 PM Ready to connect.
06-11-2018 09:16 AM
I can connect to the VPN, the creds for the APIC is not correct.
06-11-2018 05:54 PM
Hi Aaron, we had some issues with the VPN that were fixed over the weekend. My credentials are working fine and I can access the APIC.
