11-02-2019 06:07 PM
Good Day Team,
https://developer.cisco.com/site/sandbox/anyconnect/ does not have the 64 bit version of Anyconnect on it since as per https://support.apple.com/en-us/HT208436, Anyconnect is no longer working on MAC.
Can anyone solve this issue?
Himank Pande
Solved! Go to Solution.
11-02-2019 07:45 PM
11-02-2019 07:45 PM
11-02-2019 07:59 PM
11-02-2019 08:30 PM
11-24-2019 09:18 PM - edited 11-24-2019 09:18 PM
Starting with macOS Catalina, 32-bit apps are no longer compatible with macOS. When you attempt to open 32-bit AnyConnect, you will see an alert that the app needs to be updated to work with this version of macOS, or that the app is not optimized for your Mac and needs to be updated.
The current AnyConnect version 4.8 has solved this issue so you can move to the download page to get the latest version (64-bit).
Someone has uninstalled the AnyConnect Client on macOS Catalina or Mojave, but without using a graphical uninstaller (just by dragging the folder from the applications bin into the trash bin). While any further attempts to reinstall the software fail. So make sure you have fully uninstalled the old version before continuing.
