Catalyst Center always on lab
charliekay
Does it support ansible?
Ruben Cocheno
@charliekay
i didnt try, but as far you are able to use the REST API native on ansible you should be fine.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
