Cisco DNA Center Release with ISE lab - DNAC / ISE not loadning
cnelvitigala1
Catalyst Center Sandbox - Cisco DNA Center Release with ISE lab loads .
But after VPN connect , Cisco Catalyst-Center Controller:IP: 10.10.20.85 or ISE Server: IP: 10.10.20.25 does not load as HTTPS ..
Any suggestion or Fix
@cnelvitigala1 there was an issue yesterday and team put the sandbox in unplanned maintenance mode. I would check back later in the day to see if there has been any updates.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
cnelvitigala1
Thanks @bigevilbeard
I checked today .. DNAC loaded this time   . But ISE still not loading .."Application server is initializing.
You will be automatically redirected to the login page."
when i do a ssh for ISE it gives Auth error with correct password "login as: admin
admin@10.10.20.25's password:"   so seem still SIE fully laoding
cnelvitigala1
almost after 45 minutes, ISE also fully loaded   ...  it's much slow to load than week ago   ..
But i can see DNAC and ISE both as Up now .. !
Thanks !
