CML LAB Not starting
karam.nashwan
Good Morning/Afternoon Everyone;
Yesterday I tried to use CML and it works fine, I reserved CML Personal for the 2H token and everything was normal.
However, today I was trying to do the same thing but the LAB is not started and the 2nd email that should be sent to me never arrived. Instead, I got the below-attached error.
Your help is highly appreciated.
Thanks.
Martin L
Something happened on DevNet side; nothing you can do. Try new reservation after waiting few minutes or an hour or so;
Regards, ML
**Please Rate All Helpful Responses **
tom_minerd
I'm currently experiencing issues getting into CML. It worked fine for me yesterday but today it will not complete the setup. So I tried doing a teardown of the lab so I could start over. Of course that didn't work so now I'm stuck at the concurrent lab limit but unable to get into my current lab.
I got same issue; it seems they doing upgrading or updating CML Or it is so busy they don't have any open sockets for us.  I check later when it is not rush hour traffic but it seems to be missing from
https://devnetsandbox.cisco.com/RM/Topology
Regards, ML
tom_minerd
This is the output from the reservation:
20:44:14 Environment Driver Setup has begun
Beginning sandbox setup
Preparing connectivity
Apps deployment started
Apps are being discovered...
Connecting all apps
Apps are powering on...
Waiting for apps IP addresses, this may take a while...
No apps to configure
Sandbox setup finished successfully
20:46:16 Just a moment - a few more things left to setup...
20:46:21 Setting POD Internet access policy
20:46:22 Waiting 4 minutes for all systems be become fully ready
20:50:25 Calling Setup on applicable resources
20:50:49 Beginning Setup for resource [Cisco Modeling Labs_2e6a-a0d5]
20:50:50 Beginning Setup for resource [DevBox_cf8b-a0d5]
Setting up Network policy
Done
Network Setup Complete!!!
20:51:03 Completed Setup for resource [DevBox_cf8b-a0d5]
