Showing results forĀ
Search instead forĀ
Did you mean:Ā
Connection lost after connecting to VPN
Lamin
Hello everyone,
I have reserved a sandbox to play around with even  though I'm not completely sure what I anm trying to achieve.
I have downloaded the Cisco AnyConnect VPN the setup seem to be working fine, however once I am conncted to the VPN I lost access to Internet or acces to the Developer.cisco.com. What could possibly be causing this issue?
That should not be the case, the sandbox vpn uses split tunnel - which sandbox did you reserve please?
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
