DCNM DEVNET LAB_ANYCONNECT CONNECTION causes internet to drop
VPN LOGIN SUCCESSFUL using ANYCONNECT MOBILITY CLIENT - then, my INTERNET CONNECTION DROPS - have to disconnect from VPN to restore connection. Per instruction, have (unchecked) "Block connections to untrusted servers."
[anyconnect-win-4.9.04043-core-vpn-predeploy-k9.msi ] | was INSTALLED
Why am I losing my internet connection? Please advise.
Try turning off IPV6 on your WIFI and LAN adaptors.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Thank you team, will do.
Meanwhile, by checking "Allow local LAN access" in AnyConnect setup box, I am able to access DevNet and DCNM lab compnents - but lose any additional internet access.
Working on it, any suggestions please advise.
Check your DNS when connected on the VPN.
