01-27-2025 09:00 AM
I Followed the link to
https://devnetsandbox.cisco.com/DevNet/catalog/Catalyst-Center-Always-On_catalyst-center-always-on
to access - Catalyst Center Always-On v2.3.3.6
The link in the instruction : https://sandboxdnac.cisco.com
This page prompts for user login - Once login is successful, it gives the error,
If the problem continues, contact the site owner.
01-27-2025 01:45 PM
hello senthil.
I reviewed your request but im not seeing your login issue. I also tried in incognito mode and all is ok. Can i kindly suggest you try again and failing that you may try https://sandboxdnac2.cisco.com as a backup service. Also, may i suggest that you reserve the Catalyst Center Sandbox (reservable sandbox which is different than the AO sandbox that you are trying to access) .
Please come back to us with your follow up questions.
01-28-2025 05:25 AM
