DNAC-Sandbox-SJC problems
mateusz.ozga
Cisco DNA Center Lab 2 has problems with accessing the switches.
DNA Center is not able to poll (SNMP or SSH access) the Catalyst switches.
Can you please check configuration on management switch?
POD: 1321
Sandbox id: cea18f03-67fa-40a2-adfd-5ed003673d2d
Also, I cannot access the 3850/9300 switches from devbox(10.10.20.20) or my machine.
Matt
5 Replies 5
Did the sandbox come up error-free? Might be worth killing that reservation and starting a new one.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
No errors in the console log.
All catalyst switches and WLC went up without any issues.
I had the same problems in Saturday, so I tried reserve the same lab again today.
Are you able to clarify the configuration on the POD switch (the management switch which will give you access to all of the components)?
Matt
Sadly no, I am not on the ENG team for sandbox I cannot give that, however, my past reservations have not had this issue for this sandbox.
@bigevilbeard are you able to check with ENG Team?
I still have this issue, even post maintenance this weekend.
(currently on this sandbox)
Sandbox ID: d3de2b69-3e84-4278-8033-be8b13c5bee6
14:40:17 Environment Driver Setup has begun
Beginning sandbox setupPreparing connectivityApps deployment startedApps are being discovered...Connecting all appsConnecting all routesApps are powering on...Waiting for apps IP addresses, this may take a while...No apps to configureSandbox setup finished successfully14:41:47 Just a moment - a few more things left to setup...
14:41:55 Setting POD Internet access policy
14:42:00 Calling Setup on applicable resources
14:42:19 Beginning Setup for resource [DNA-Center_C]
14:42:19 Beginning Setup for resource [C3850_C]
14:42:21 Completed Setup for resource [DNA-Center_C]
14:42:22 Beginning Setup for resource [C9300-24UX-1_C]
14:42:22 Completed Setup for resource [C3850_C]
14:42:24 Beginning Setup for resource [C9300-24UX-2_C]
14:42:26 Completed Setup for resource [C9300-24UX-1_C]
14:42:28 Completed Setup for resource [C9300-24UX-2_C]
14:42:33 Adding user mateusz.ozga on VPN, for POD 1321, VLAN 1421
14:42:41 VPN CONNECTION INFORMATION
VPN  Network: devnetsandbox-usw1-reservation.cisco.com:21421
    Username: REDACTED
    Password: REDACTED
Sending email with VPN Credentials.
14:42:47 Lab Setup Complete.  Lab is ready for use!
14:42:49 Driver Complete.
The ENG team check this forum, but I have asked them to take a look.
Hope this helps.
