10-14-2019 02:11 PM
Hi Devnet Community,
I'm currently running the Multi-IOS Cisco Test Network Lab Sandbox Lab and coming across an error when trying to run the command "virl generate nso"
The error is:
[developer@devbox ~]$virl generate nso
Updating NSO....
Exception raised while running your command
Please open an issue and provide this info:
HTTPConnectionPool(host='10.10.20.50', port=8080): Max retries exceeded with url: /api/config/devices/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f247446fdd8>: Failed to establish a new connection: [Errno 111] Connection refused',))
I tried running this command on different available virl topologies (ie - virlfiles/2-ios-router | virlfiles/core-dist-access) but with the same result.
Any ideas from any how this can be fixed so I can do some NSO labbing?
Any feedback is most appreciated.
Charles
Solved! Go to Solution.
10-15-2019 03:43 AM
10-15-2019 03:43 AM
10-15-2019 05:51 AM
Thanks for that.
For this instance, to get it working (for other's reference), the below is done:
1)source /opt/nso/ncsrc
2)create a directory for NCS logs and files and within this directory run "ncs-setup --dest ."
3)start ncs daemon - "ncs" and confirmation daemon is working by running "ncs --status"
Now once above is done there's no more error messages by running "virl generate nso" which adds the VIRL devices to NSO.
Cheers
