How to reopen my last CML lab, and how to clean old labs
amirzkria2
Hi Guys,
If someone knows how can I open my last LAB, every time when I start a new session it create a new LAB?
And how can I clean up my old LABs?
Torbjørn
1 - You can save the config to your lab with the "Config > Fetch" button in the Node pane in CML. After that is done you can export/download the lab under "Lab > Download Lab" on the top bar of CML. See image below.
2 - This are just historic sessions. All "Ended" sessions won't consume any resources from the available pool and I don't think you can delete entries from this list.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Torbjørn
Hello @amirzkria2, welcome to the community!
Due to the nature of the Devnet sandboxes you don't get any persistence between sessions. You can however save + export the node configs and export the CML lab so that you can import it again in your next session. Have fun labbing!
amirzkria2
Thanx @Torbjørn for your reply.
1- how to export/import LAB setting
2- How to clean up old labs, as you can see in my attachment many labs not used
Torbjørn
