Meraki Always-On DevNet Sandbox Lab will not launch
PVS92
I have tried several times over the last week or two to launch the Meraki always-on DevNet Sandbox and it has failed every time. On the website I will see a message stating "Oops. Launch failed", with the environment link and I recieve an email with the following:
There was an error setting up Meraki Always On.
There are a few possible reasons for the error:
  • No resource available by this moment
  • The sandbox is under maintenance
  • You try to reserve two or more sandboxes simultaneously
Please try relaunching the sandbox to reboot the process.
I do not have any other sandboxes open. I have tried launching the sandbox several times over different days of the week and different times of the day.
Is it common for this to fail due to lack of resources, or is there something else that could cause this issue on my end?
@PVS92 its a popular sandbox, and as you noted maybe already fully booked. Maybe tried the reservation one in the mean time?
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
I figured that may be the case, but wanted to check. Thank you! I will keep trying every so often.
