02-23-2024 07:07 AM
Both the reservable Enterprise and Small Business Sandboxes seem to be broken. None of the Meraki devices that should be loaded are online and there are all types of strange network names, each containing 'broken' Meraki devices.
02-24-2024 03:26 PM
I don't recall to see all devices up while using those Labs, but was able to work on the lab without any problems.
02-26-2024 12:51 AM
02-26-2024 05:27 AM
Hi @jubor,
If the sandbox has been updated but the learning lab has not, then this can cause a discrepancy about what you should be seeing in the sandbox. Usually there are only a few sandboxes per technology, such as Meraki, but there may be dozens of tracks/modules/labs that use the sandbox and that are often updated later to match the changes in a sandbox. I'm not saying that's what the issue is here...it's just something to consider...if you can skip a section and proceed in the lab, you might want to do that.
