Nexus Mgmt port connectivity
sheeraz.hussain
I have connected 2 x Nexus 9000 back to back using Mgmt port but see below when i did show cap neigh
SW1(config)# sh cdp ne
Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
S - Switch, H - Host, I - IGMP, r - Repeater,
V - VoIP-Phone, D - Remotely-Managed-Device,
s - Supports-STP-Dispute
Device-ID Local Intrfce Hldtme Capability Platform Port ID
switch(9YV6VWB5Q5E)
Eth1/2 138 R S s N9K-9000v mgmt0
Total entries displayed: 1
7 Replies 7
balaji.bandi
how we can prove that interface connected to right ? may be connected interface correct as show in your output.
so to verify, show interface status of both to confirm the correct connection.
not that i was saying you connected wrong, just clarify ?
BB
I did verify and that's the only connection i have... so no chance to misread that :)
Just to verify, i have shutdown E1/2 and the neighbor is gone, but as soon as i no shut E1/2 the CDP neighbor is back... some is not right and developers need to take a look.
SW1(config-if)# sh cdp ne
Total entries displayed: 0
SW1(config-if)# int e1/2
SW1(config-if)# no shut
switch(9YV6VWB5Q5E)
Eth1/2 127 R S s N9K-9000v mgmt0
can you post show version to see any bugs around ?
if possible post the information i was asked for reference.
BB
Hi @sheeraz.hussain
What do you see on the peer Nexus when you do show cdp neighbor?
Can you enable LLDP feature on both Nexus switches and then show lldp neighbor?
Sergiu
switch(9YV6VWB5Q5E)
I will reserve another slot soon and capture the show version information.
FYI
I don't have that issue when using Eve-ng.
Well, definitely looks like a bug :-)
