06-08-2017 08:54 AM - edited 06-04-2019 02:30 AM
Hi, I got this error when try to to connect to CIMC sanbox through anyconnect.
The secure gateway has rejected the connection attempt. A new connection attempt to the same or another secure gateway is needed, which requires re-authentication. The following message was received from the secure gateway: No assigned address
Jeyaram
Probit Systems
06-08-2017 10:10 AM
hello Jeyaram. Please re-try connecting to the session. you had an inactive session to the pod that has been cleared.
06-09-2017 11:20 AM
Thank you. able to connect .working now. Really appreciate.
Jeyaram
