Remote Expert Mobile Sandbox access by Android SDK
Yuki Iwagishi
Is there any documentation how to access Sandbox from Remote Expert Mobile Android SDK?
matfarre
Level 6
Level 6
Be sure to check out the Learning Lab on Remote Expert Mobile Cisco DevNet Learning Labs and the enclosed links to the pre-staged REM overview pages.  The Getting Started page has information regarding deployment/installation of the components of Remote Expert Mobile.  Also, appears more information is under development and coming soon.
Matt
dstaudt
The current RE Mobile lab is accessed via Cisco AnyConnect VPN, so there would be two main options:
- Install and configure AnyConnect on the Android device using the VPN connection info that you should receive via email when the lab is reserved.  This may be problematic as AnyConnect is not available/supported on all Android versions/devices.
- Configure an available router (e.g. a Cisco 800 series) to connect to the lab via VPN, and connect the Android device to the router
Thanks! So firstly we should connect AnyConnect VPN on Android. I've confirmed it works on AnyConnect on Android.
Then SDK should be modified to this environment based on tutorial's hello world section.
https://developer.cisco.com/site/remote-expert-mobile/learn/developer-tutorials/
https://developer.cisco.com/media/remote-expert-mobile-developer-tutorials/android-sdk/03-hello-world/hello-world.html
