01-07-2016
02:22 AM
- 最終編集日:
06-04-2019
09:49 AM
、編集者:
Paul Zimmerman
Hi All,
I have just started looking in to remote expert and have been using the Cisco Sandbox to start off with some development.
So far I haven't had much luck with getting an audio or video connection.
Both browser and android applications are working for co-browsing, but initiating a call results in black boxes with no audio for bot the agent and caller.
This worked briefly between browsers a couple of days ago but nothing since.
Has anyone else had trouble with this?
Are there any gotchas I need to look out for with the VPN or anything?
Thanks for any replies,
Shane Griffin
01-07-2016 02:32 AM
Hi Shane,
Much of the remote expert mobile support is in the US so they will be online in a few hours. I have extended your reservation to account for your problem.
I will take a look at the environment in the and see if all of your servers are good.
Joe
01-07-2016 11:10 AM
This was working for me just last night, though I did notice that calls would not complete using Firefox under Linux (Chrome worked fine.)
It may be helpful if you can grab the browser console output (F12, select Console) and attach here.
01-08-2016 02:18 AM
Console output form agent side. Login to call end. Sorry I just grabbed everything, nothing is jumping out at me to explain this.
adapter.js:123 This appears to be Chrome
csdk-common.js:92 Detected User Agent was: [chrome]
csdk-common.js:112 CSDK version: [2,1,31,11]
shared-windows.js:42 Loaded shared-windows.js
assist-console.js:126 Setting screenShareActive callback.
assist-console.js:131 Setting screenShareRejectedCallback
assist-console-callmanager.js:182 set remote video element
assist-console-callmanager.js:173 set local video element
assist-console.js:150 Setting callEndedCallback.
assist-console.js:145 Setting consumerLeftCallback.
assist-console.js:139 Setting consumerJoinedCallback.
assist-console.js:56 Setting connectionRetryCallback.
assist-console.js:63 Setting connectionReestablishedCallback.
assist-console.js:42 Setting connectivityLostCallback.
expert-assist-console.js:688 Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check http://xhr.spec.whatwg.org/.
assist-console-callmanager.js:222 Session Token: nrr%3A%21%21ja.ja.ia.ff%3Acggh%21DJqFnJl%21nFIrvHzFqHJyy%3FJuuzFl%3D5N4N-eFggEHIe-hEHI-ggjc-JIch-ijHHjbjGdhIF
csdk-common.js:138 received sessionId nrr%3A%21%21ja.ja.ia.ff%3Acggh%21DJqFnJl%21nFIrvHzFqHJyy%3FJuuzFl%3D5N4N-eFggEHIe-hEHI-ggjc-JIch-ijHHjbjGdhIF
csdk-common.js:140 Using URI wss://10.10.20.55:8443/gateway/websocketcall?appkey=FWGW-6e44fcb6-3fcb-4418-ab83-21cc191d73be
csdk-common.js:145 Phone available, adding
csdk-phone.js:661 Using LocalMediaGeneratorChrome
csdk-phone.js:1447 'webkitAudioContext' is deprecated. Please use 'AudioContext' instead.
csdk-phone.js:1123 UC.phone is supported - Creating a UC.phone
csdk-phone.js:1269 User-Agent: [Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/47.0.2526.106 Safari/537.36]
csdk-common.js:447 Socket Down, queing message for sending
csdk-common.js:150 Presence available, adding
csdk-common.js:155 AED available, adding
csdk-aed.js:40 Creating Chrome/IE/Firefox AED
csdk-common.js:356 Fri Jan 08 2016 10:06:37 GMT+0000 (GMT) Info: Opening WebSocket wss://10.10.20.55:8443/gateway/websocketcall?appkey=FWGW-6e44fcb6-3fcb-4418-ab83-21cc191d73be
csdk-phone.js:762 Requesting access to local media with mediaConstraints: [{"audio":true,"video":{"mandatory":{},"optional":[{"minWidth":640},{"minHeight":480},{"maxWidth":640},{"maxHeight":480},{"minFrameRate":15},{"maxFrameRate":15}]}}]
csdk-phone.js:707 User has granted access to local media.
csdk-phone.js:1533 Element was not defined, not attaching stream
csdk-phone.js:1131 [[object Object]] - Firing onLocalMediaStream() callback
csdk-phone.js:3543 Local media acquired by phone object: [[object MediaStream]]
12csdk-common.js:447 Socket Down, queing message for sending
csdk-common.js:368 Fri Jan 08 2016 10:06:39 GMT+0000 (GMT) Info: WebSocket connection opened.
csdk-common.js:464 Sending: {"type":"CAPABILITIES","user-agent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/47.0.2526.106 Safari/537.36"}
csdk-common.js:464 Sending: {"type":"INITIALISE"}
csdk-common.js:382 Received: [{"type":"PING"}]
csdk-common.js:464 Sending: {"type":"PONG"}
csdk-common.js:382 Received: [{"type":"INITIALISATION_SUCCESS","swift-version":2}]
csdk-common.js:172 Firing onInitialised()
assist-console-callmanager.js:229 UC onInitialised fired
csdk-phone.js:1136 [[object Object]] - setPreviewElement() with: [[object HTMLDivElement]]
csdk-phone.js:1549 Attaching media stream: [[object MediaStream]] to element: [[object HTMLDivElement]]
4expert-assist-console.js:515 csdk session is still alive. Will check again in 30000ms
csdk-common.js:382 Received: [{"type":"CONNECT","callId":"GW_786844183525062002","remoteAddress":"assist-2v57f6ad5kigfsdgfief3la41"}]
csdk-common.js:464 Sending: {"type":"RINGING","callId":"GW_786844183525062002"}
csdk-phone.js:1224 onIncomingCall() with: [Call: id [GW_786844183525062002], remote address [assist-2v57f6ad5kigfsdgfief3la41], remote display name [], elapsed time [0:00]]
assist-console-callmanager.js:234 incoming call: GW_786844183525062002
csdk-common.js:382 Received: [{"type":"CALL_CONFIG","callId":"GW_786844183525062002","iceServers":[]}]
csdk-phone.js:2154 Creating peer connection with iceServers []
csdk-phone.js:2489 Created RTCPeerConnnection with:
config: '{"iceServers":[]}';
constraints: '{}'.
csdk-phone.js:1850 Generating media for call: [GW_786844183525062002]
csdk-phone.js:1858 Local Media Stream not available yet, waiting to generate SDP
csdk-common.js:382 Received: {"type":"MULTIPART","content":"[{\"type\":\"OFFER\",\"callId\":\"GW_786844183525062002\",\"sdp\":\"v=0\\r\\no=- 1259531974 1 IN IP4 10.10.20.55\\r\\ns=-\\r\\nc=IN IP4 10.10.20.55\\r\\nt=0 0\\r\\na=group:BUNDLE audio video\\r\\na=msid-semantic: WMS RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4T\\r\\nm=audio 16001 RTP/SAVPF 111 0 8 18\\r\\na=rtpmap:111 opus/48000/2\\r\\na=fmtp:111 minptime=10;\\r\\na=rtpmap:0 PCMU/8000\\r\\na=rtpmap:8 PCMA/8000\\r\\na=rtpmap:18 G729/8000\\r\\na=sendrecv\\r\\na=rtcp:1 IN IP4 10.10.20.55\\r\\na=rtcp-mux\\r\\na=candidate:789654123 1 udp 1 10.10.20.5","multipartID":1,"finalMultipartID":6}
csdk-common.js:382 Received: {"type":"MULTIPART","content":"5 16001 typ host generation 0\\r\\na=candidate:789654123 2 udp 1 10.10.20.55 16001 typ host generation 0\\r\\na=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:y9b13RFg6GUjzyJljKD0BBxz8LCkDqdB97ygg6nQ\\r\\na=fingerprint:sha-256 DB:50:F4:D4:98:30:62:E3:5D:E3:99:BC:43:6D:A4:A3:41:F2:6D:D7:79:40:8A:D5:D7:B7:D4:C3:2D:03:E9:44\\r\\na=ice-ufrag:C4ifIho9\\r\\na=ice-pwd:woN5ppmi0pv8E4h2rWQTCpZJ\\r\\na=ssrc:2600966580 cname:plgGCXcacVLPNAGi\\r\\na=ssrc:2600966580 msid:RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4T RYqffdk6JFBFBGaXeaNPe","multipartID":2,"finalMultipartID":6}
csdk-common.js:382 Received: {"type":"MULTIPART","content":"iPElJN3Uep40l4Ta0\\r\\na=ssrc:2600966580 mslabel:RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4T\\r\\na=ssrc:2600966580 label:RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4Ta0\\r\\na=mid:audio\\r\\na=setup:actpass\\r\\nm=video 16001 RTP/SAVPF 100 97\\r\\na=rtpmap:100 VP8/90000\\r\\na=rtcp-fb:100 nack\\r\\na=rtcp-fb:100 ccm fir\\r\\na=rtcp-fb:100 nack pli\\r\\na=rtcp-fb:100 goog-remb\\r\\na=rtpmap:97 H264/90000\\r\\na=fmtp:97 profile-level-id=42801E;packetization-mode=0;level-asymmetry-allowed=1\\r\\na=rtcp-fb:97 nack\\r\\na=rtcp-fb:97 ccm fir\\r","multipartID":3,"finalMultipartID":6}
csdk-common.js:382 Received: {"type":"MULTIPART","content":"\\na=rtcp-fb:97 nack pli\\r\\na=rtcp-fb:97 goog-remb\\r\\na=sendrecv\\r\\na=rtcp:1 IN IP4 10.10.20.55\\r\\na=rtcp-mux\\r\\na=imageattr:100 send [x=640,y=480] [x=320,y=240] [x=272,y=224] [x=224,y=176] [x=176,y=144] recv [x=640,y=480] [x=320,y=240] [x=272,y=224] [x=224,y=176] [x=176,y=144]\\r\\na=imageattr:97 send [x=640,y=480] [x=320,y=240] [x=272,y=224] [x=224,y=176] [x=176,y=144] recv [x=640,y=480] [x=320,y=240] [x=272,y=224] [x=224,y=176] [x=176,y=144]\\r\\na=candidate:789654123 1 udp 1 10.10.20.55 16001 typ","multipartID":4,"finalMultipartID":6}
csdk-common.js:382 Received: {"type":"MULTIPART","content":" host generation 0\\r\\na=candidate:789654123 2 udp 1 10.10.20.55 16001 typ host generation 0\\r\\na=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:y9b13RFg6GUjzyJljKD0BBxz8LCkDqdB97ygg6nQ\\r\\na=fingerprint:sha-256 DB:50:F4:D4:98:30:62:E3:5D:E3:99:BC:43:6D:A4:A3:41:F2:6D:D7:79:40:8A:D5:D7:B7:D4:C3:2D:03:E9:44\\r\\na=ice-ufrag:C4ifIho9\\r\\na=ice-pwd:woN5ppmi0pv8E4h2rWQTCpZJ\\r\\na=ssrc:4291643493 cname:plgGCXcacVLPNAGi\\r\\na=ssrc:4291643493 msid:RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4T RYqffdk6JFBFBGaXeaNPeiPElJN3Uep4","multipartID":5,"finalMultipartID":6}
csdk-common.js:382 Received: {"type":"MULTIPART","content":"0l4Tv0\\r\\na=ssrc:4291643493 mslabel:RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4T\\r\\na=ssrc:4291643493 label:RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4Tv0\\r\\na=mid:video\\r\\na=setup:actpass\\r\\n\",\"remoteParty\":\"assist-2v57f6ad5kigfsdgfief3la41\"}]","multipartID":6,"finalMultipartID":6}
csdk-common.js:269 Combined: [{"type":"OFFER","callId":"GW_786844183525062002","sdp":"v=0\r\no=- 1259531974 1 IN IP4 10.10.20.55\r\ns=-\r\nc=IN IP4 10.10.20.55\r\nt=0 0\r\na=group:BUNDLE audio video\r\na=msid-semantic: WMS RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4T\r\nm=audio 16001 RTP/SAVPF 111 0 8 18\r\na=rtpmap:111 opus/48000/2\r\na=fmtp:111 minptime=10;\r\na=rtpmap:0 PCMU/8000\r\na=rtpmap:8 PCMA/8000\r\na=rtpmap:18 G729/8000\r\na=sendrecv\r\na=rtcp:1 IN IP4 10.10.20.55\r\na=rtcp-mux\r\na=candidate:789654123 1 udp 1 10.10.20.55 16001 typ host generation 0\r\na=candidate:789654123 2 udp 1 10.10.20.55 16001 typ host generation 0\r\na=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:y9b13RFg6GUjzyJljKD0BBxz8LCkDqdB97ygg6nQ\r\na=fingerprint:sha-256 DB:50:F4:D4:98:30:62:E3:5D:E3:99:BC:43:6D:A4:A3:41:F2:6D:D7:79:40:8A:D5:D7:B7:D4:C3:2D:03:E9:44\r\na=ice-ufrag:C4ifIho9\r\na=ice-pwd:woN5ppmi0pv8E4h2rWQTCpZJ\r\na=ssrc:2600966580 cname:plgGCXcacVLPNAGi\r\na=ssrc:2600966580 msid:RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4T RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4Ta0\r\na=ssrc:2600966580 mslabel:RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4T\r\na=ssrc:2600966580 label:RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4Ta0\r\na=mid:audio\r\na=setup:actpass\r\nm=video 16001 RTP/SAVPF 100 97\r\na=rtpmap:100 VP8/90000\r\na=rtcp-fb:100 nack\r\na=rtcp-fb:100 ccm fir\r\na=rtcp-fb:100 nack pli\r\na=rtcp-fb:100 goog-remb\r\na=rtpmap:97 H264/90000\r\na=fmtp:97 profile-level-id=42801E;packetization-mode=0;level-asymmetry-allowed=1\r\na=rtcp-fb:97 nack\r\na=rtcp-fb:97 ccm fir\r\na=rtcp-fb:97 nack pli\r\na=rtcp-fb:97 goog-remb\r\na=sendrecv\r\na=rtcp:1 IN IP4 10.10.20.55\r\na=rtcp-mux\r\na=imageattr:100 send [x=640,y=480] [x=320,y=240] [x=272,y=224] [x=224,y=176] [x=176,y=144] recv [x=640,y=480] [x=320,y=240] [x=272,y=224] [x=224,y=176] [x=176,y=144]\r\na=imageattr:97 send [x=640,y=480] [x=320,y=240] [x=272,y=224] [x=224,y=176] [x=176,y=144] recv [x=640,y=480] [x=320,y=240] [x=272,y=224] [x=224,y=176] [x=176,y=144]\r\na=candidate:789654123 1 udp 1 10.10.20.55 16001 typ host generation 0\r\na=candidate:789654123 2 udp 1 10.10.20.55 16001 typ host generation 0\r\na=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:y9b13RFg6GUjzyJljKD0BBxz8LCkDqdB97ygg6nQ\r\na=fingerprint:sha-256 DB:50:F4:D4:98:30:62:E3:5D:E3:99:BC:43:6D:A4:A3:41:F2:6D:D7:79:40:8A:D5:D7:B7:D4:C3:2D:03:E9:44\r\na=ice-ufrag:C4ifIho9\r\na=ice-pwd:woN5ppmi0pv8E4h2rWQTCpZJ\r\na=ssrc:4291643493 cname:plgGCXcacVLPNAGi\r\na=ssrc:4291643493 msid:RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4T RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4Tv0\r\na=ssrc:4291643493 mslabel:RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4T\r\na=ssrc:4291643493 label:RYqffdk6JFBFBGaXeaNPeiPElJN3Uep40l4Tv0\r\na=mid:video\r\na=setup:actpass\r\n","remoteParty":"assist-2v57f6ad5kigfsdgfief3la41"}]
assist-console-callmanager.js:245 incoming call accepted: GW_786844183525062002
csdk-phone.js:2619 [Call: id [GW_786844183525062002], remote address [assist-2v57f6ad5kigfsdgfief3la41], remote display name [], elapsed time [0:00]] - setVideoElement() with: [[object HTMLDivElement]]
csdk-phone.js:1537 Stream was not defined, not attaching stream
csdk-phone.js:2592 [Call: id [GW_786844183525062002], remote address [assist-2v57f6ad5kigfsdgfief3la41], remote display name [], elapsed time [0:00]] - answer() with audio: [true], video: [true]
csdk-phone.js:2267 [Call: id [GW_786844183525062002], remote address [assist-2v57f6ad5kigfsdgfief3la41], remote display name [], elapsed time [0:00]] - Firing onLocalMediaStream() callback
csdk-phone.js:3906 onLocalMediaStream: Got Media Stream: [object MediaStream]
csdk-phone.js:2078 Call in state: [0] - Call has not been accepted by the user, not generating SDP
csdk-phone.js:2042 Call in state: [1], triggering SDP negotiation
csdk-phone.js:2054 Remote party offered, generating Answer
csdk-phone.js:1940 Call with stream: 1SFVDB7B0DyuPjh8g0sFolWCazkKLztxvxHR
expert-assist-console.js:529 No calls in queue, will not show Inbound call prompt
csdk-phone.js:2352 [Call: id [GW_786844183525062002], remote address [assist-2v57f6ad5kigfsdgfief3la41], remote display name [], elapsed time [0:00]] - Firing onRemoteMediaStream() with: [[object MediaStream]]
csdk-phone.js:3933 onRemoteMediaStream: Got Media Stream: [object MediaStream]
csdk-phone.js:1682 Adding image attributes to the SDP we are sending out
csdk-common.js:461 Splitting: {"type":"ANSWER","callId":"GW_786844183525062002","sdp":"v=0\r\no=- 5646260762451111204 2 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE audio video\r\na=msid-semantic: WMS 1SFVDB7B0DyuPjh8g0sFolWCazkKLztxvxHR\r\nm=audio 9 RTP/SAVPF 111 0 8\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:ZFgsMVtld7Bg4Boy\r\na=ice-pwd:aOtvXSSneivPphDgv1xC62rj\r\na=fingerprint:sha-256 E7:AD:A7:E7:C4:D3:6C:23:D2:A7:38:04:4B:9F:C6:6E:59:50:29:B3:28:09:92:CA:5D:62:58:9A:09:D9:3F:1A\r\na=setup:active\r\na=mid:audio\r\na=sendrecv\r\na=rtcp-mux\r\na=rtpmap:111 opus/48000/2\r\na=fmtp:111 minptime=10; useinbandfec=1\r\na=rtpmap:0 PCMU/8000\r\na=rtpmap:8 PCMA/8000\r\na=maxptime:60\r\na=ssrc:2520412357 cname:N24FemV31svCp6L0\r\na=ssrc:2520412357 msid:1SFVDB7B0DyuPjh8g0sFolWCazkKLztxvxHR 57f2257c-c8b0-4714-b22f-94cac0af05fa\r\na=ssrc:2520412357 mslabel:1SFVDB7B0DyuPjh8g0sFolWCazkKLztxvxHR\r\na=ssrc:2520412357 label:57f2257c-c8b0-4714-b22f-94cac0af05fa\r\nm=video 9 RTP/SAVPF 100\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:ZFgsMVtld7Bg4Boy\r\na=ice-pwd:aOtvXSSneivPphDgv1xC62rj\r\na=fingerprint:sha-256 E7:AD:A7:E7:C4:D3:6C:23:D2:A7:38:04:4B:9F:C6:6E:59:50:29:B3:28:09:92:CA:5D:62:58:9A:09:D9:3F:1A\r\na=setup:active\r\na=mid:video\r\na=sendrecv\r\na=rtcp-mux\r\na=rtpmap:100 VP8/90000\r\na=rtcp-fb:100 ccm fir\r\na=rtcp-fb:100 nack\r\na=rtcp-fb:100 nack pli\r\na=rtcp-fb:100 goog-remb\r\na=ssrc:402926881 cname:N24FemV31svCp6L0\r\na=ssrc:402926881 msid:1SFVDB7B0DyuPjh8g0sFolWCazkKLztxvxHR 6a029383-0432-47ae-87aa-13fe15005173\r\na=ssrc:402926881 mslabel:1SFVDB7B0DyuPjh8g0sFolWCazkKLztxvxHR\r\na=ssrc:402926881 label:6a029383-0432-47ae-87aa-13fe15005173\r\na=imageattr:* send [x=176,y=144] [x=224,y=176] [x=272,y=224] [x=320,y=240] [x=640,y=480] [x=1280,y=720] recv [x=176,y=144] [x=224,y=176] [x=272,y=224] [x=320,y=240] [x=640,y=480] [x=1280,y=720]"}
csdk-common.js:464 Sending: {"type":"MULTIPART","multipartID":1,"finalMultipartID":4,"content":"{\"type\":\"ANSWER\",\"callId\":\"GW_786844183525062002\",\"sdp\":\"v=0\\r\\no=- 5646260762451111204 2 IN IP4 127.0.0.1\\r\\ns=-\\r\\nt=0 0\\r\\na=group:BUNDLE audio video\\r\\na=msid-semantic: WMS 1SFVDB7B0DyuPjh8g0sFolWCazkKLztxvxHR\\r\\nm=audio 9 RTP/SAVPF 111 0 8\\r\\nc=IN IP4 0.0.0.0\\r\\na=rtcp:9 IN IP4 0.0.0.0\\r\\na=ice-ufrag:ZFgsMVtld7Bg4Boy\\r\\na=ice-pwd:aOtvXSSneivPphDgv1xC62rj\\r\\na=fingerprint:sha-256 E7:AD:A7:E7:C4:D3:6C:23:D2:A7:38:04:4B:9F:C6:6E:59:50:29:B3:28:09:92:CA:5D:62:58:9A:09:D9:3F:1A\\r\\na=setup:active"}
csdk-common.js:464 Sending: {"type":"MULTIPART","multipartID":2,"finalMultipartID":4,"content":"\\r\\na=mid:audio\\r\\na=sendrecv\\r\\na=rtcp-mux\\r\\na=rtpmap:111 opus/48000/2\\r\\na=fmtp:111 minptime=10; useinbandfec=1\\r\\na=rtpmap:0 PCMU/8000\\r\\na=rtpmap:8 PCMA/8000\\r\\na=maxptime:60\\r\\na=ssrc:2520412357 cname:N24FemV31svCp6L0\\r\\na=ssrc:2520412357 msid:1SFVDB7B0DyuPjh8g0sFolWCazkKLztxvxHR 57f2257c-c8b0-4714-b22f-94cac0af05fa\\r\\na=ssrc:2520412357 mslabel:1SFVDB7B0DyuPjh8g0sFolWCazkKLztxvxHR\\r\\na=ssrc:2520412357 label:57f2257c-c8b0-4714-b22f-94cac0af05fa\\r\\nm=video 9 RTP/SAVPF 100\\r\\nc=IN IP4 0.0.0.0"}
csdk-common.js:464 Sending: {"type":"MULTIPART","multipartID":3,"finalMultipartID":4,"content":"\\r\\na=rtcp:9 IN IP4 0.0.0.0\\r\\na=ice-ufrag:ZFgsMVtld7Bg4Boy\\r\\na=ice-pwd:aOtvXSSneivPphDgv1xC62rj\\r\\na=fingerprint:sha-256 E7:AD:A7:E7:C4:D3:6C:23:D2:A7:38:04:4B:9F:C6:6E:59:50:29:B3:28:09:92:CA:5D:62:58:9A:09:D9:3F:1A\\r\\na=setup:active\\r\\na=mid:video\\r\\na=sendrecv\\r\\na=rtcp-mux\\r\\na=rtpmap:100 VP8/90000\\r\\na=rtcp-fb:100 ccm fir\\r\\na=rtcp-fb:100 nack\\r\\na=rtcp-fb:100 nack pli\\r\\na=rtcp-fb:100 goog-remb\\r\\na=ssrc:402926881 cname:N24FemV31svCp6L0\\r\\na=ssrc:402926881 msid:1SFVDB7B0DyuPjh8g0sFolWCaz"}
csdk-common.js:464 Sending: {"type":"MULTIPART","multipartID":4,"finalMultipartID":4,"content":"kKLztxvxHR 6a029383-0432-47ae-87aa-13fe15005173\\r\\na=ssrc:402926881 mslabel:1SFVDB7B0DyuPjh8g0sFolWCazkKLztxvxHR\\r\\na=ssrc:402926881 label:6a029383-0432-47ae-87aa-13fe15005173\\r\\na=imageattr:* send [x=176,y=144] [x=224,y=176] [x=272,y=224] [x=320,y=240] [x=640,y=480] [x=1280,y=720] recv [x=176,y=144] [x=224,y=176] [x=272,y=224] [x=320,y=240] [x=640,y=480] [x=1280,y=720]\"}"}
csdk-common.js:464 Sending: {"type":"ICE_CANDIDATE","candidate":"candidate:3456331231 1 udp 2122194687 10.2.0.212 57553 typ host generation 0","sdpMLineIndex":0,"sdpMid":"audio","callId":"GW_786844183525062002"}
csdk-common.js:464 Sending: {"type":"ICE_CANDIDATE","candidate":"candidate:908558445 1 udp 2122260223 192.168.210.25 57980 typ host generation 0","sdpMLineIndex":0,"sdpMid":"audio","callId":"GW_786844183525062002"}
csdk-common.js:464 Sending: {"type":"ICE_CANDIDATE","candidate":"candidate:2155909423 1 tcp 1518214911 10.2.0.212 0 typ host tcptype active generation 0","sdpMLineIndex":0,"sdpMid":"audio","callId":"GW_786844183525062002"}
csdk-common.js:464 Sending: {"type":"ICE_CANDIDATE","candidate":"candidate:2024045725 1 tcp 1518280447 192.168.210.25 0 typ host tcptype active generation 0","sdpMLineIndex":0,"sdpMid":"audio","callId":"GW_786844183525062002"}
csdk-common.js:382 Received: [{"type":"OK","callId":"GW_786844183525062002"}]
csdk-common.js:382 Received: [{"type":"ESTABLISHED","callId":"GW_786844183525062002"}]
csdk-phone.js:2172 [Call: id [GW_786844183525062002], remote address [assist-2v57f6ad5kigfsdgfief3la41], remote display name [], elapsed time [0:00]] - Firing onInCall() callback
expert-assist-console.js:727 retrieving share items from urlPath = resourcemanager/urls?guid=b4abe788-89dc-cf3f-963c-f3721bb56eaa
csdk-phone.js:2613 [Call: id [GW_786844183525062002], remote address [assist-2v57f6ad5kigfsdgfief3la41], remote display name [], elapsed time [0:00]] - setPreviewElement() with: [[object HTMLDivElement]]
assist-aed.js:449 Info: Socket connection for topic assist-2v57f6ad5kigfsdgfief3la41 opened.
assist-console.js:635 Participant joined: role = agent
assist-aed.js:80 Join topic message received for topic 0 from 1
assist-console.js:635 Participant joined: role = consumer
assist-console.js:638 Calling consumerJoinedCallback.
assist-aed.js:99 Leave topic message received for topic 0 from 1
assist-console.js:644 Participant left; role = consumer
assist-console.js:653 Calling consumerLeftCallback.
expert-assist-console.js:397 setConsumerLeftCallback (consumer network issues)
csdk-common.js:382 Received: [{"type":"END","callId":"GW_786844183525062002","reason":null}]
csdk-phone.js:2186 [Call: id [GW_786844183525062002], remote address [assist-2v57f6ad5kigfsdgfief3la41], remote display name [], elapsed time [0:27]] - Firing onEnded() callback
expert-assist-console.js:90 Consumer left Agent Assist pages.
expert-assist-console.js:595 The call queue is empty ![]()
01-19-2016 12:52 PM
Are you trying to use the 'Collaboration Endpoints' lab or the dedicated 'Remote Expert Mobile' lab?
03-01-2016 12:08 AM
I am using our application on latest chrome: Version 48.0.2564.116
During the call I am getting error on remote video hold/resume. In console I am getting below line
Element was not defined, not attaching stream:
Remote party answered, generating OK
fcsdk-phone.js:2435 Call with stream: eHHAfv421FyozYZdbIJRFV1Vqh2XINkbC4Kg
fcsdk-common.js:665 Sending: {"type":"OK","callId":"GW-1"}
fcsdk-phone.js:1900 Element was not defined, not attaching stream
fcsdk-phone.js:2867 [Call: id [GW-1], remote address [1111001-20161301-011344], remote display name [FAS Caller], elapsed time [0:26]] - Firing onRemoteMediaStream() with: [[object MediaStream]]
fcsdk-phone.js:4894 onRemoteMediaStream: Got Media Stream: [object MediaStream]
fcsdk-phone.js:2847 [Call: id [GW-1], remote address [1111001-20161301-011344], remote display name [FAS Caller], elapsed time [0:28]] - Firing onVideoStreamAdded() with: [content]
fcsdk-phone.js:4944 onRemoteVideoAdded(): The stream with Id [content] has been removed
fcsdk-phone.js:2850 [Call: id [GW-1], remote address [1111001-20161301-011344], remote display name [FAS Caller], elapsed time [0:28]] - Firing onRemoteVideoResized() with: [640], [480], [content]
fcsdk-phone.js:4921 onRemoteVideoResized(): The stream: [content] has been resized to: [640] by [480]
fcsdk-phone.js:2855 Uncaught TypeError: Cannot set property 'videoWidth' of undefined
Can anyone help me on this..?
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
