Sandbox CI/CD pipeline for infrastructure automation - Issue
ricardo_rojas
    Hello all, It is not possible to connect to the virtual switches, there is a connectivity issue, thanks for your support.
  • Virtual switches that are part of the CML simulation can be reached over SSH at the following
  • IPv4 addresses: 10.10.20.177, 10.10.20.178
Best regards,
Ricardo Rojas
@ricardo_rojas can you reach these from the devbox in the sandbox? Might be also worth looking into the CML UI and checking the IP addresses are correct there.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
ricardo_rojas
Hello, yes I can reach them from the netbox   According to the lab instructions, I should access these IPs: 10.10.20.50 (DevBox), 10.10.20.161 (CML), 10.10.20.177 (virtual Nexus switch), and 10.10.20.178 (virtual Nexus switch). The first two work, but I can’t reach the others from my laptop. I’m looking for labs where I can access Nexus 9300(NX-OS 9.x) devices to play with RESTCONF. Can you please suggest any?
That might be a gateway/routing issue, check the switch config. You could alway just run this from devbox, there is always the always on nexus sandbox, which is reachable without vpn. I used to build back to back nexus in virtual box and run these locally on my macbook, as the nx9k images isn that big.
Hope this helps.
