sandbox lab and TSP
Hi  .. need to understand which sandbox lab shall we use for testing. We have to do the CTI integration with CUCM 9.1.
Also what should we used for development tapi32.dll / CISCO TSP? do we need TSP if we are using sandbox lab for testing?
77 Replies 77
Under 'User Management', either Application User/End User:
Hi ,
Since couple of hours i can not connect to sandbox using AnyConnect VPN. Is there any issue with sandbox?
Getting error - "Connection attempt failed. Please try again"
This is my sandbox lab address
devnetsandboxlabs.cisco.com/rave04
Hello Bhushan-
Thanks for reporting your issue. We experienced s brief VPN outage related to your devnetsandboxlabs.cisco.com/rave04 network. Service has been restored, would you please try connecting again and let me know if it working out okay for you?
Thanks!
Jacob
Thanks Jacob! It's working now.
Now CUCM is not opening.
This is the IP of lab -
64.103.37.21
Getting same error again.
Error - "Connection attempt failed. Please try again"
Also, can you please increase the duration of the lab? Can you set it to one month?
I have added all the suggested permissions. I can login to CUCM using newly created end user.
I have added new user in TSP configuration and restarted telephony service. But inside the dialer we can not see the CISCO lines/devices.
Lab address -
TSP Trace Log -
17:06:56.019 HDR|02/18/2016 CiscoTSP001.tsp,Special
17:06:56.019 |   TSPI_lineNegotiateTSPIVersion() dwDeviceID =0xFFFFFFFF dwLowVersion =0x00010003 dwHighVersion =0x00030001 lpdwTSPIVersion =0x01A2506C
17:06:56.097 |   CSelsiusTSPWaveList::Init() *ERROR* Failed to get ISelsiusNTWaveCtl interface.
17:06:56.097 |   SelsiusTSP::InitializeComObjects() *ERROR* Failed m_WaveList->Init(). hr=0x80040154
17:06:56.156 |   TSPI_lineNegotiateTSPIVersion()
        TSPI_lineNegotiateTSPIVersion returns = 0x00000000
        TSPI return version = 0x00020001
17:06:56.156 |   TSPI_providerEnumDevices()
        dwPermanentProviderID = 0x00000005
        hProvider = 0x01A25050
        lpfnLineCreateProc = 0xEFEDC930
        lpfnPhoneCreateProc = 0xEFEF2D6C
        TSPI_providerEnumDevices returns = 0x00000000
        dwNumLines = 0
        dwNumPhones = 0
17:06:56.156 |   TSPI_providerInit()
        dwTSPIVersion = 0x00020001
        lpfnCompletionProc = 0xEFEFBDB8
        TSPI_providerInit returns = 0x00000000
        dwLineDeviceIDBase = 0x00000005
        dwPhoneDeviceIDBase = 0x00000000
        dwNumLines = 0
        dwNumPhones = 0
        lpdwTSPIOptions = 0x01A25068
Can you connect to the VPN now?
Joe
I have created Collaboration 10.5 sandbox lab and can connect using AnyConnect VPN.
I login to given lab address using browser but when i am opening CUCM then its not opening.
Is there any issue with the LAB VPN?
This is my lab network address -
devnetsandboxlabs.cisco.com/rave15
Checking this now,
Joe
I have just connected to that VLAN over VPN and accessed the CUCM publisher and subscriber successfully.
are you seeing an error? can you ping the IP addresses? 10.10.20.1 and 10.10.20.2.
Joe
I can ping these IP address. It's not giving any error but it is very slow and got stuck in middle of processing.
I can see the CUCM publisher and CUCM subscriber page. But get stuck when click on Cisco unified communication manager link.
Can you use a full anyconnect client tunnel when Accessing the sandbox? SSL VPN is not set up.
Joe
