SD-WAN lab vpn s not responding?
Jason.yin
Hi ALL,
Does anybody know why SD-WAN lab vpn is not responding?
https://devnetsandbox.cisco.com/RM/Diagram/Index/eba946cf-80f8-4b0c-a7df-404c52c80833
I am using the lab recommended anyconnect version, but getting  error message is below:anyconnectvpn.png
Jason
gomez.esteban
Too bad for me as well, no connection to vpn.
Hello, sorry you are having an issue with the VPN to the sandbox. Are the ports range between 20100 and 20354 is open via your firewall? This message is normally seen when the ports are blocked outbound.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
