SD-WAN Sandbox Connectivity Issues
ShashidharKrishnaswamy3383
Community Member
Hi Cisco Team,
I am not able to  connect to Cisco Sandbox via VPN. I am following the instructions based on the email sent to me:
The connection is very flaky.
ping devnetsandbox-emea-gwy.cisco.com:20246
64 bytes from 92.242.140.21: icmp_seq=629 ttl=246 time=38.743 ms
64 bytes from 92.242.140.21: icmp_seq=630 ttl=246 time=39.430 ms
64 bytes from 92.242.140.21: icmp_seq=631 ttl=246 time=44.304 ms
64 bytes from 92.242.140.21: icmp_seq=632 ttl=246 time=42.258 ms
64 bytes from 92.242.140.21: icmp_seq=633 ttl=246 time=39.479 ms
64 bytes from 92.242.140.21: icmp_seq=634 ttl=246 time=38.146 ms
64 bytes from 92.242.140.21: icmp_seq=635 ttl=246 time=37.886 ms
64 bytes from 92.242.140.21: icmp_seq=636 ttl=246 time=42.445 ms
64 bytes from 92.242.140.21: icmp_seq=637 ttl=246 time=46.971 ms
64 bytes from 92.242.140.21: icmp_seq=638 ttl=246 time=39.816 ms
64 bytes from 92.242.140.21: icmp_seq=639 ttl=246 time=44.266 ms
64 bytes from 92.242.140.21: icmp_seq=640 ttl=246 time=37.187 ms
64 bytes from 92.242.140.21: icmp_seq=641 ttl=246 time=37.597 ms
64 bytes from 92.242.140.21: icmp_seq=642 ttl=246 time=39.992 ms
64 bytes from 92.242.140.21: icmp_seq=643 ttl=246 time=45.835 ms
64 bytes from 92.242.140.21: icmp_seq=644 ttl=246 time=40.683 ms
64 bytes from 92.242.140.21: icmp_seq=645 ttl=246 time=48.276 ms
64 bytes from 92.242.140.21: icmp_seq=646 ttl=246 time=40.012 ms
64 bytes from 92.242.140.21: icmp_seq=647 ttl=246 time=37.713 ms
64 bytes from 92.242.140.21: icmp_seq=648 ttl=246 time=50.303 ms
64 bytes from 92.242.140.21: icmp_seq=649 ttl=246 time=40.816 ms
64 bytes from 92.242.140.21: icmp_seq=650 ttl=246 time=38.983 ms
64 bytes from 92.242.140.21: icmp_seq=651 ttl=246 time=40.098 ms
64 bytes from 92.242.140.21: icmp_seq=652 ttl=246 time=38.949 ms
64 bytes from 92.242.140.21: icmp_seq=653 ttl=246 time=68.625 ms
64 bytes from 92.242.140.21: icmp_seq=654 ttl=246 time=46.343 ms
64 bytes from 92.242.140.21: icmp_seq=655 ttl=246 time=40.986 ms
64 bytes from 92.242.140.21: icmp_seq=656 ttl=246 time=42.243 ms
64 bytes from 92.242.140.21: icmp_seq=657 ttl=246 time=39.517 ms
64 bytes from 92.242.140.21: icmp_seq=658 ttl=246 time=49.120 ms
64 bytes from 92.242.140.21: icmp_seq=659 ttl=246 time=39.835 ms
64 bytes from 92.242.140.21: icmp_seq=660 ttl=246 time=39.916 ms
64 bytes from 92.242.140.21: icmp_seq=661 ttl=246 time=45.287 ms
64 bytes from 92.242.140.21: icmp_seq=662 ttl=246 time=38.286 ms
64 bytes from 92.242.140.21: icmp_seq=663 ttl=246 time=37.204 ms
64 bytes from 92.242.140.21: icmp_seq=664 ttl=246 time=40.207 ms
64 bytes from 92.242.140.21: icmp_seq=665 ttl=246 time=50.525 ms
64 bytes from 92.242.140.21: icmp_seq=666 ttl=246 time=41.673 ms
Request timeout for icmp_seq 667
Request timeout for icmp_seq 668
Request timeout for icmp_seq 669
Request timeout for icmp_seq 670
Request timeout for icmp_seq 671
Request timeout for icmp_seq 672
Request timeout for icmp_seq 673
64 bytes from 92.242.140.21: icmp_seq=674 ttl=246 time=39.283 ms
Request timeout for icmp_seq 675
Request timeout for icmp_seq 676
Request timeout for icmp_seq 677
Request timeout for icmp_seq 678
Request timeout for icmp_seq 679
Request timeout for icmp_seq 680
64 bytes from 92.242.140.21: icmp_seq=681 ttl=246 time=38.251 ms
Request timeout for icmp_seq 682
Request timeout for icmp_seq 683
Request timeout for icmp_seq 684
Request timeout for icmp_seq 685
Can you please fix the issue?
Shashi
10 Replies 10
Hi there, in this case you are not pinging the sandbox, but the VPN gateway - the sandbox is behind the VPN. When you had the VPN connected were you not able to access the vManage front page?
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hi, I am having the issue mentioned. I can not access the vmanage via gui, cli does work briefly then locks up on all devices, pings to the lab devices are timing out often, I have stopped and restarted the devices and also tried canceling the reservations and testing again. My local network is fine no issues. Any suggestions would be great. @bigevilbeard
Sure - can you advise if this is the reserved sd-wan sandbox, the always on sd-wan sandbox or the virl version please?
Thanks!
The SD-WAN lab shows Ver 18.3
Thanks - Did you reserve this one and get VPN details?
Yes, I got connected fine to the VPN, just high latency, I could login to device via cli and then it would lockup. I tried vmanage in multiple browsers it would not pull up at all. There seems to be an issue with that server.
I just now completed testing on the UCS Director lab and it ran with no issues.(Director,Manager,Central)
Thanks - in this case we need sandbox engineering team to comment here.
I have the same issues on the sdwan reserved lab. High latency and packet loss to sdwan lab devices. Vmanage gui eventually opens but extremely slow. Template pushes timeout 9 out of 10 times.
I have let the devnet sandbox engineering team aware of this issue
