        IMPORTANT! The sandboxes that can be reserved will be undergoing maintenance
from 12:01AM PDT Friday May 21 until 11:59PM Sunday May 23.
During this time, reserved sandboxes will be unavailable.
Always-On sandboxes are not affected and should still be available.
259
rwu
Beginner
Beginner
The IOS XE on Catalyst 9000 Sandbox problem
Hi, I was quite excited to try using DEVNET Sandbox, but it seems that DEVBOX is not allowed to have Internet access by design. For the sandbox "The IOS XE on Catalyst 9000 Sandbox", I can't even import requests. Tried installed some packages by using winscp to transfer some folders from my computer to DEVBOX and tried different commands such as "python setup.py install" but all of them don't work. It showed something like "pip install 'module' object has no attribute 'check_specifier'". Quite disappointing. Could the support team please help take a look at this Sandbox?
Appreciate it!
1 REPLY 1
bigevilbeard
Hello, you are correct the devbox does not have internet access for security reasons, i do not see this changing right now. Some basic tools are installed on the devbox from a local repo with the sandbox infra which can be installed to be used with the learning lab which accompanies this sandbox.
Hope this helps.
Content for Community-Ad
