Trouble accessing CUCM Administration portal for publisher of sandbox CUCM v11.0
rkorn
I'm having trouble accessing the CUCM Administration portal for publisher of sandbox CUCM v11.0 on the rave37 network. This happened on the rave34 network, so I shut terminated the session and started over. It gave rave37 which failed to start the subscriber. I shut it down again and on the third try got rave37 again with the original issue. Pinging 10.10.20.1 from the windows rdp gives me destination unreachable.
jokearns1
Richard,
Sounds like your sandbox is just not playing ball today.
We are checking on this now and will get back to you shortly.
Joe
Wonderful, thank you.
Any update? Should I try a new instance?
Richard,
To save time, i suggest terminating your current session and reserving again. There seems to be an issue with that particular IP address on rave37. We need time to troubleshoot.
Can you cancel your current reservation and rebook? you will pick up a different network.
Joe
