VPN connection problems to Sandbox
I have  issues connecting to devnet VPN since morning :
    4:09:55 PM    Contacting devnetsandbox-emea-gwy.cisco.com:20232.
    4:10:40 PM    Connection attempt has failed.
    4:10:40 PM    Unable to contact devnetsandbox-emea-gwy.cisco.com.
I'm working on SD-WAN POD. Please let me know if th
12 Replies 12
omz
There are few reports of issues with VPN connections.
DevNet ENG is aware of the issues and working to resolve.
hope this helps
Hey there i tested this morning via the API/SD-WAN UI (see timestamp) connected to GW devnetsandbox-emea-gwy.cisco.com:20191 - trying tearing down the reservations and grabbing a new one. Hope this helps
(venv) STUACLAR-M-R6EU:sd_wan_demo stuaclar$ date
Wed  8 Apr 2020 10:59:54 BST
(venv) STUACLAR-M-R6EU:sd_wan_demo stuaclar$ time python get_devices.py
│ Host Name   │ Device IP   │ Site ID    │ Host ID                              │ Host Type   │
│ vmanage-01  │ 4.4.4.90    │ vmanage-01 │ e85cd6d5-4dea-46a1-affb-38fd4cd8debd │ vmanage     │
│ vsmart-01   │ 4.4.4.70    │ vsmart-01  │ 50cb5f09-3b74-49b7-aa5a-c17db012206c │ vsmart      │
│ vbond-01    │ 4.4.4.80    │ vbond-01   │ 8163a199-96b2-4886-9b20-bcb9fce4bf88 │ vedge-cloud │
│ vedge-001   │ 4.4.4.60    │ vedge-001  │ 100faff9-8b36-4312-bf97-743b26bd0211 │ vedge-cloud │
│ vedge-002   │ 4.4.4.61    │ vedge-002  │ f3d4159b-4172-462c-9c8d-8db76c31521d │ vedge-cloud │
│ vedge-003   │ 4.4.4.64    │ vedge-003  │ 0435c3e8-d3a0-4c6b-af0a-f95d41974d69 │ vedge-cloud │
│ vedge-004   │ 4.4.4.65    │ vedge-004  │ 46c18a49-f6f3-4588-a49a-0b1cc387f179 │ vedge-cloud │
real	0m1.808s
user	0m0.160s
sys	0m0.059s
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
I'm still having issues when connecting to my VPN id below :
does your post mean will I get a new VPN id .Also I cannot access SDWAN lab without connecting to VPN. Let me know if I have to tear down the current lab and need to have a new reservation?
Sai
You can go into your reservations and 'end' you current session. Once this is done you can reserve a new one (you can only reserve one sandbox at once due to security limits). You will then get a new ID and session.
Hope that helps.
I have teardown the Lab and registered a new one. However I'm unable to connect VPN with new ID. I tried both on Mac/Windows ,either ways it is same issue.
   10:15:23 AM    Contacting devnetsandbox-emea-gwy.cisco.com:20205.
    10:16:08 AM    Connection attempt has failed.
    10:16:08 AM    Unable to contact devnetsandbox-emea-gwy.cisco.com.
Do you if the sandbox ports are blocked from your location? The port range will be anywhere from TCP 20100 through TCP 20354. If that's not working, keep in mind VPNs also use TLS (TCP 443) and DTLS (UDP 443). Though typically these are open in most organizations.
Thanks!
I'm using personal laptop trying access from home internet. Tried from both Mac/Windows laptop and still the same issue . Is it possible to have a one to one session to make sure I'm doing it right?
Sai
Sadly i cannot offer that level of support here.
The issue seems to be with my ISP. I can VPN after I connect through my hotspot. Now I can access SD-WAN lab. However 3 devices out of 7 are still not reachable after I VPN. Ping failes to :
ping 10.10.20.65
PING 10.10.20.65 (10.10.20.65): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
I cannot ping devices from 10.10.20.61 ,10.10.20.62,10.10.20.64,10.10.20.65
Reserving a sandbox to check, please standby.
I reserved a new sandbox this morning and do not see the same issue (see ping output below).
(venv) STUACLAR-M-R6EU:~ stuaclar$ ping 10.10.20.60 -c 3
PING 10.10.20.60 (10.10.20.60): 56 data bytes
64 bytes from 10.10.20.60: icmp_seq=0 ttl=63 time=44.516 ms
64 bytes from 10.10.20.60: icmp_seq=1 ttl=63 time=62.479 ms
64 bytes from 10.10.20.60: icmp_seq=2 ttl=63 time=44.880 ms
--- 10.10.20.60 ping statistics ---
3 packets transmitted, 3 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 44.516/50.625/62.479/8.383 ms
(venv) STUACLAR-M-R6EU:~ stuaclar$ ping 10.10.20.61 -c 3
PING 10.10.20.61 (10.10.20.61): 56 data bytes
64 bytes from 10.10.20.61: icmp_seq=0 ttl=63 time=47.133 ms
64 bytes from 10.10.20.61: icmp_seq=1 ttl=63 time=44.198 ms
64 bytes from 10.10.20.61: icmp_seq=2 ttl=63 time=89.284 ms
--- 10.10.20.61 ping statistics ---
round-trip min/avg/max/stddev = 44.198/60.205/89.284/20.597 ms
(venv) STUACLAR-M-R6EU:~ stuaclar$ ping 10.10.20.64 -c 3
PING 10.10.20.64 (10.10.20.64): 56 data bytes
64 bytes from 10.10.20.64: icmp_seq=0 ttl=63 time=46.629 ms
64 bytes from 10.10.20.64: icmp_seq=1 ttl=63 time=42.239 ms
64 bytes from 10.10.20.64: icmp_seq=2 ttl=63 time=41.755 ms
--- 10.10.20.64 ping statistics ---
round-trip min/avg/max/stddev = 41.755/43.541/46.629/2.192 ms
(venv) STUACLAR-M-R6EU:~ stuaclar$ ping 10.10.20.65 -c 3
64 bytes from 10.10.20.65: icmp_seq=0 ttl=63 time=43.553 ms
64 bytes from 10.10.20.65: icmp_seq=1 ttl=63 time=73.655 ms
64 bytes from 10.10.20.65: icmp_seq=2 ttl=63 time=42.767 ms
--- 10.10.20.65 ping statistics ---
round-trip min/avg/max/stddev = 42.767/53.325/73.655/14.379 ms
Can you open the vManage via the UI? https://10.10.20.90:8443/ - Here you should see the WAN edge devices all in the upstate.
I'm trying to use the Open NX-OS with Nexus 9Kv sandbox and tried VPNing but got this same error. I stopped the lab and reserved another one and have the same issue. Any idea how to fix this? This are the gateways I've gotten:
devnetsandbox-emea-gwy.cisco.com:20209
devnetsandbox-emea-gwy.cisco.com:20211
