VPN Connection to Sandbox fails using AnyConnect for Linux
txo
When I reserve the PxGrid 2.0 on ISE 3.0 sandbox I can connect properly using AnyConnect for Windows but I am trying to connect from connect from Linux and I get the following error:
Cisco AnyConnect Secure Mobility Client (version 4.9.06037) .
Copyright (c) 2004 - 2021 Cisco Systems, Inc.  All Rights Reserved.
  >> state: Disconnected
  >> notice: Ready to connect.
  >> registered with local VPN subsystem.
VPN> connect devnetsandbox-usw1-reservation.cisco.com:20200
  >> contacting host (devnetsandbox-usw1-reservation.cisco.com:20200) for login information...
  >> notice: Contacting devnetsandbox-usw1-reservation.cisco.com:20200.
  >> Please enter your username and password.
Group: SSLClient
Username: [***********] T**********
Password:
  >> state: Connecting
  >> notice: Establishing VPN session...
The AnyConnect Downloader is analyzing this computer. Please wait...
Initializing the AnyConnect Downloader...
The AnyConnect Downloader is performing update checks...
  >> notice: The AnyConnect Downloader is performing update checks...
The AnyConnect Downloader updates have been completed.
Please wait while the VPN connection is established...
  >> notice: Checking for profile updates...
  >> notice: Checking for product updates...
  >> notice: Checking for customization updates...
  >> notice: Performing any required updates...
  >> notice: The AnyConnect Downloader updates have been completed.
  >> notice: Establishing VPN - Initiating connection...
  >> state: Disconnecting
  >> notice: Disconnect in progress, please wait...
  >> error: VPN establishment capability for a remote user is disabled.  A VPN connection will not be established.
VPN> goodbye...
It seems that the VPN does not accept connections from Linux Clients.
Please, could you enable linux connections?
As far as i am aware, there is no restriction on VPN in the sandbox when connecting. Have you tried Open Connect for Linux? https://developer.cisco.com/docs/openconect-sandbox/
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hope this helps.
Open Connect is working fine!
Thanks for your help
Awesome!
I have reserve Cisco SD-WAN 19.2 lab and while trying to connect from Linux using AnyConnect, getting below error
Cisco AnyConnect Secure Mobility Client (version 4.9.05042) .
Copyright (c) 2004 - 2020 Cisco Systems, Inc. All Rights Reserved.
>> state: Disconnected
>> state: Disconnected
>> contacting host (devnetsandbox-usw1-reservation.cisco.com:20374) for login information...
>> notice: Contacting devnetsandbox-usw1-reservation.cisco.com:20374.
Group: SSLClient
Username: ********
Password: ********
>> state: Connecting
>> state: Connecting
>> state: Disconnected
VPN>
could you please help to resolve this,
cant use OpenConnect because of risk mentioned in below note,
Please Note: While this works well in most cases, we can't officially support the OpenConnect method at this time. Please use at your own risk.
