When try Cisco NSO Reservation Sandbox get error Sandbox lab not found
Achraf.Talbi
Hey,
    I tried yesterday and to day to access "NSO Reservation Sandbox" to reserve a  Sandbox lab but I get all time the error "Sandbox lab not found".
    Is there a problem in the reservation of this lab ?
 Thanks for your response.
  Achraf
@Achraf.Talbi the ENG team are working on an issue with this sandbox. It has for now been taken out of the catalog. Please check back later and this should be good to go!
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Thanks @bigevilbeard  for your response.
At which time it will be available ? Because I'm learning NSO with lab all this day and I want to know how long will I be blocked.
Achraf
@Achraf.Talbi this was/is unplanned and emergency work required, there is no time provided in this case as the team undertake and fix the sandbox. You can use the always-on NSO version here -->  https://devnetsandbox.cisco.com/RM/Diagram/Index/aa07cf66-b756-4424-99c1-4a93aa42c913?diagramType=Topology
Hope this helps.
