Alex Stevenson
Inspiration and Purpose
The idea for this project came from our team’s desire to attach audio versions of the blogs and articles we post to the Cisco Community. This will enable those who are visually impaired and give everyone else the option to listen instead of reading. I also wanted to have a place to store all my blog and article documents, other than a folder on my desktop. This source of truth (SOT) of text templates and their associated audio MP3s will also serve as an archive for future use of this knowledge.
The continuous integration (CI) pipeline which I’m about to share is worth sharing because it accomplishes two things in particular, which you may have assumed GitHub Actions would do out of the box, but for which I had to do some research to find and implement niche tools. These two things are:
1) Detect exactly which file(s) have changed in a Push to GitHub and assign the properties of those files to variables.
2) After running a script using those variables, automatically Commit and Push back into the GitHub repository.
Setting up the Directories in GitHub
We almost always post in the Developer Hub area of the Cisco Community, so I just needed to model that structure in GitHub.
Here’s the contents of the Developer Hub, as seen online:
I created a new GitHub repository (repo) named “community-content-pipeline” and added a directory called “developer-hub” where I replicated the structure from the website.
Now, whenever I post a new article or blog in the Developer Hub, I will also upload my original docx document here, in the appropriate subfolder. Now, let’s automate some CI magic!
GitHub Actions Workflow
In order to setup a GitHub Action, we create a YAML file in a /.github/workflows/ directory we create in our GitHub repo. Mine is laid out like this:
community-content-pipeline/.github/workflows/make_mp3_on_push.yml
The first thing I did, besides naming it, was to set this workflow to only run on a PUSH to the repo and only if the files being pushed are located in the developer-hub directory and end in ‘.docx’ (this is the standard file format currently used by Microsoft Office – Word).
name: Create MP3 from .docx upon Push to a developer-hub directory
on:
  push:
  #only runs when files in this path are changed, and they must end in .docx
    paths:
      - developer-hub/**.docx
Now, I needed to find a way to see exactly which file changed in the Push and assign it to a variable for working with it in the Python script we’ll compose later. This action does just the trick, and it’s found on GitHub Marketplace as well:
trilom/file-changes-action
Here’s how I’ve used it in the workflow to see which files are added or modified and feed them to the Python script we’ll make:
      - id: file_changes # see which file changed in the push, in '' string output
        uses: trilom/file-changes-action@v1.2.3
        with:
          outout: ''
          fileOutput: ''
      - name: test # print modified and added files
        run:    |
          echo 'modified file(s) = ${{ steps.file_changes.outputs.files_modified}}'
          echo 'added file(s) = ${{ steps.file_changes.outputs.files_added}}'
      - name: execute py script # run file
        env:
          MODIFIED_FILE: ${{ steps.file_changes.outputs.files_modified}}
          ADDED_FILE: ${{ steps.file_changes.outputs.files_added }}
        run: |
          python3 action_txt_2_mp3.py
Ok, the workflow is almost done. Now, I needed to tell the workflow to commit the changes the Python script will make and push them back into the repo. That is accomplished, thanks to the following GitHub Action, also found on the GitHub Marketplace:
ad-m/github-push-action
Here's that part of the workflow:
      - name: Commit files # transfer the new files back into the repository
        run: |
          git config --local user.name "xanderstevenson"
          git add .
          git commit -m "Updating the repository, with mp3 in the ./mp3s folder"
      - name: Push changes # push the output folder to your repo
        uses: ad-m/github-push-action@master
        with:
          github_token: ${{ secrets.GITHUB_TOKEN }}
          force: true
Alright! We’re almost there. Now, we just need to write the Python script we’ve invoked in the workflow and we’ll be good to go!
Python Script to Convert Text-to-Speech
Remember the variables ‘MODIFIED_FILE’ and ‘ADDED_FILE’ we created in the workflow? Let’s import them into our Python script.
if __name__ == "__main__":
    #import environmental variable from the GitHub actions workflow
    # get the file that changed or was added and strip the brackets and quotes
    the_modified_filename = os.getenv('MODIFIED_FILE')
    the_modified_filename = the_modified_filename.replace('[','').replace(']','').replace('"','')
    the_added_filename = os.getenv('ADDED_FILE')
    the_added_filename = the_added_filename.replace('[','').replace(']','').replace('"','')
Now, we’ve got the name of the file that changed. But we still need its basepath as Python sees it. Here’s the method I used to do that:
base_path = os.path.dirname()
We have the filename and basepath and now I want to create a directory named after the file that changed. This was how I got that to happen:
    # get the filename of the document
    file_name = str(os.path.basename(txt_filepath).rsplit(".", 1)[0])
    file_name = file_name.replace(" ", "-")
    txt_dirname = mp3_base_path + f"/{file_name}/"
    if not os.path.exists(txt_dirname):
        os.makedirs(txt_dirname)
Translating a docx to a MP3 was not working, so I found I had to convert the DOCX to a TXT first. I installed docx2txt for that and used it as follows. I also needed to format the resulting txt io remove URLs and empty lines, which could make the MP3 sound annoying when read in text-to-speech:
    try:
        # convert docx to txt
        my_text = docx2txt.process(docx_filepath)
        # remove all URLs from text
        my_text = re.sub(r"http\S+", "", my_text)
        # create and write text to txt file
        with open(txt_file, "w") as text_file:
            print(my_text, file=text_file)
        #remove original docx
        os.remove(docx_filepath)
    ### removing empty lines
        # Read lines as a list
        workable_txt = open(txt_file, "r")
        lines = workable_txt.readlines()
        workable_txt.close()
        # Weed out blank lines with filter
        lines = filter(lambda x: not x.isspace(), lines)
        # Write
        workable_txt = open(txt_file, "w")
        workable_txt.write("".join(lines))
Finally, we feed the TXT file to the gTTS module I’ve installed and save the MP3 to a new sub-directory we create called ‘mp3s.
        # open and read .txt file
        with open(txt_file, 'r') as f:
            the_text = f.read()
            # conversion to MP3
            mp3 = gTTS(the_text, lang="en", tld=accent)
            # strip filename from filepath
            file_name = str(os.path.basename(txt_file).rsplit('.', 1)[0])
            # if the 'mp3s' directory does not exist, create it
            if not os.path.exists(txt_dirname + '/mp3s/'):
                os.makedirs(txt_dirname + '/mp3s/')
                time.sleep(3)
            # name and save mp3
            mp3_filename = txt_dirname + '/mp3s/' + file_name
            mp3_filename += '.mp3'
            mp3.save(mp3_filename)
At this point in the workflow, the following will be committed and pushed to the repo:
  1. A new folder, named for your .docx file, inside of which will be:
    1. A downloadable copy of the original DOCX document
    2. A readable TXT version of the document
    3. A downloadable MP3, inside of an 'mp3s' sub-folder
Demo
Let’s see this baby in action! I have a DOCX document, named “DevSecOps-Defined”, which contains text, images, links and URLs.
 To read the DevSecOps Defined article, just click on the image.
All I need to do is upload and commit it to the appropriate directory in my repo, which in this case is community-content-pipeline/developer-hub/developer-security/security-knowledge-base/
That will start the build process that is detailed in our Workflow. GitHub Actions does the rest.
The entire Build, Test and Report process for CI took GitHub Actions about 30 seconds to complete; not too bad! Here are the results: a new directory named “DevSecOps-Defined” with our DOCX and TXT files inside….
….as well as the mp3s folder with the audio inside...
Special Thanks, Source Code and Related Projects
Special thanks to John Capobianco of Cisco, whose wiktrola project provided inspiration (and a bit of code ; ) for this project.
For the complete code to my project, visit the following repository:
https://github.com/xanderstevenson/community-content-pipeline
People may want control over the accent used for text-to-speech. For that, I have created the following:
https://github.com/xanderstevenson/txt_2_mp3
This will give you the ability to choose from the following accents for the MP3:
1. English (Australia)
2. English (United Kingdom)
3. English (United States)
4. English (Canada)
5. English (India)
6. English (Ireland)
7. English (South Africa)
* An audio version of this article is attached, MP3 format/zipped
* Python code was linted with Pylint.
Ray Stephenson
Great, easy to understand example solving a real but not complex problem using GitHub actions. Awesome!
Alex Stevenson
Thank you @Ray Stephenson!
New to DevOps? These resources can help:
DevOps Resources
