cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Odd pattern in a ping
Hector Melo
What does this strange pattern mean in a ping?
4 RESPUESTAS 4
The regularity suggests a policer is being encountered. If the ping target is only one hop away (no transit hops), then such a policer is probably protecting the target’s control plane.
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
@Hector Melo hi, seems like your QoS policy is hitting at your end or destination end. check the policy statistics to find if there is any hits and drops.
Good luck
KB
Do you ping nexus or sw ios xe ?
If yes it is normal copp drop last packet since it rate threshold is exceeding.
Hector Melo
Thanks for the respond, i will check if there is a policy in the path.
Its ping to an ONT from a Cisco ASR9906. The ONT its connected to a BNG and in the PPPoE session has the policy.
The BNG is a juniper MX204.
