cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
bandwidth restriction on SVI switch 9300
ErickArteaga234
Hi all!
I have a switch model C9300-48UXM, within my configuration in the SVI 100.
I need to set the bandwidth limit to 2 Mb. when creating the class-map and policy-map:
class-map match-all VLAN_100|2MBPS
match vlan 100
policy-map VLAN_100|2MBPS
class VLAN_100|2MBPS
police cir 2120000 bc 460000 be 1420000 conform-action transmit exceed-action drop
As soon as I enter the policy-map to my vlan interface, the following log appears: Only Marking policy action is supported on SVI interface. Policy Rejected
interface Vlan100
description LAN
ip address 10.52.35.46 255.255.255.0
ip ospf 200 area 0
service-policy input VLAN_100|2MBPS
service-policy output VLAN_100|2MBPS
Mar  4 07:37:06.878:  Only Marking policy action is supported on SVI interface. Policy Rejected
For this model of equipment, what type of configuration would I need to apply to restrict the bandwidth in this SVI?
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
You can try using shaping instead policing.
There are some differences, for example:
Policing can be used in both directions
Shaping only outbound.
If you want to use policing so you can change the config through:
police cir 2120000
exceed -action drop
or apply it on the default class just for testing purporse.
class class-default
police cir 2120000
exceed -action drop
Regards.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Ver la solución en mensaje original publicado
1 RESPUESTA 1
police cir 2120000
exceed -action drop
class class-default
police cir 2120000
exceed -action drop
Regards.
