Greetings
I am configuring a POS interface (oc48) on an ASR 903 RSP2A. I have the A900-IMA3G-IMSG line card and the active license. Following the SONET POS mode configuration guide (https://www.cisco.com/c/en/us/td/docs/routers/asr903/software/guide/chassis/xe-3s/b_Config_Guide_fullbook/b-cfg- opt-int.html#task_1761094) when entering the sts-1 command, it does not give me the POS option, and I cannot create the POS interface. I can only set mode sts-48c.
I'm on firmware 16.7.1.
This is my configuration so far:
controller MediaType 0/2/16
mode sonet
controller SONET 0/2/16
rate OC48
no ais-shut
clock source internal
sts-1 1 - 48 mode sts-48c
I would appreciate any information you can give me.
Thank you
