cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Fabric error
analisan@cisco.com
Hi everybody
can you tell me what is the fabric and how it works, because I had a problem in one RSP of router 7606.
this error appeared.
FABRIC_INTF_ASIC-DFC4-5-FABRICSYNC_REQ
I found that this is a component of card that it transports the packets, but It isn´t so clear for me.
can you help me? "Fabric"
4 RESPUESTAS 4
Julio E. Moisa
Fabric term is used to represent a technology, in this case it can be associated to the technology used on the card, now this is error could be a bug or definitely the card is not working properly, you could open a case with the Cisco TAC to request a RMA.
regards,
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
Thanks for your comments you are very nice!!
regards!
luis_cordova
Hola analisan@cisco.com ,
Hay un bug reportado con un síntoma parecido.
Te dejo el link del reporte:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtz51545
Saludos
Hi Luis,
Thanks for your comments about my doubt!!
regards
