cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
FRR in NX-OS
gemv44
Hello, I am trying to simulate Fast-Rerouting in a NX-OS device running the ISIS protocol, but I can't resolve it because the command fast-reroute per-prefix level-2 all doesn't appear.
Could someone help me?
4 RESPUESTAS 4
balaji.bandi
You need to provide more information and environment and use case.
by just posting command not accepting, not have any clue here at this instance.
use case have a Looks and requirement in general
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/mpls/config/cisco_mpls_config_guide_8x/mp_te_frr_node_prot.html
BB
M02@rt37
Hello @gemv44
Which platform please ? and which NX-OS version ?
""Fast reroute link and node protection requires an MPLS license. For a complete explanation of the NX-OS licensing scheme and how to obtain and apply licenses, see the Cisco NX-OS Licensing Guide.""
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/licensing-options/cisco-nexus-licensing-options-guide.html
Thanks.
Best regards
Thak you for your answer. I tried in NX-OS 7.3 titanium and NX-OS 9500 10.1.2.
 I want to apply fast reroute over ISIS protocol, but the command fast-reroute is unrecognized. Your suggesting is for MPLS-TE, you think is the same licensing problem?
Code that I applied:
router isis pruebas
net 49.0010.0000.0000.0003.00
reference-bandwidth 100
is-type level-2
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_isis/configuration/15-s/irs-15-s-book/irs-rmte-lfa-frr.pdf
I dont think it support in NX-OS.
MHM
