le 10-16-2023 12:03 PM
Hello. I don't understand why hosts on the 192.168.10.0/24 subnet can't connect to other hosts on other subnets. I need help please.
Thats hosts cant connect to others hosts
Résolu ! Accéder à la solution.
le 10-16-2023 12:22 PM
Do the hosts on the 192.168.10.0/24 subnet have default gateways configured that point to their first-hop router? Does that first-hop router (RT10?) have a route to the other subnets in its routing table? Does the last-hop router (the one for the remote hosts) have a route back to the 192.168.10.0/24 subnet? Do the remote hosts have default gateway configurations?
le 10-16-2023 12:05 PM
I forget to mention that the cisco file of my network is for download. Sorry and thanks in advance
le 10-16-2023 12:28 PM
You are right. I forget that the RT10 need to have a route to the other subnets, my bad. Thank you so much.
Découvrez et enregistrez vos notes préférées. Revenez pour trouver les réponses d'experts, des guides étape par étape, des sujets récents et bien plus encore.
Êtes-vous nouveau ici? Commencez par ces conseils. Comment utiliser la communauté Guide pour les nouveaux membres
Navegue y encuentre contenido personalizado de la comunidad
