cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
How to upgrade CAT4500 VSS?
oscar.cuevas1
Hi everyone.
I want to upgrade a switch CAT4500 but it's in VSS with another CAT4500, I have only 2 switches in this VSS.
When I put this command:
boot system flash bootflash:CAT-IMAGE.bin  boot system flash slovebootflash:CAT-IMAGE-bin
then reload with this "redundancy reload shelf"
The vss turns up but stills in the same image.
Best regards
How could I upgrade ? are there other way to upgrade?
2 SOLUCIONES ACEPTADAS
Soluciones aceptadas
You should upload the image on both 4500, and set up the boot system flash bootflash:IMAGE
Then reboot the devices with the command: redundancy reload shelf
Regards.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Ver la solución en mensaje original publicado
oscar.cuevas1
Updated.
The issue was the image wasn't correct.
Thanks for your help.
2 RESPUESTAS 2
Regards.
oscar.cuevas1
Updated.
