cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Nexus IPN Monitoring
sebasmegot
Hello there!
I have a query regarding a monitoring process.
A customer is planning to monitor the interfaces via SNMP of a nexus 7000 that is in the context of IPN through Zabbix, in researching I noticed that the compatibility matrix only mentions the nexus 9000, not any model of the 7000, any of you were in a scenario where you had to carry out this configuration and it was successful?
Attached is an image of the ip of interest along with the configuration to the IPN (on the zabbix side it does not stretch any parameters).
1 RESPUESTA 1
balaji.bandi
that configuration you showed that should work, what SNMP version try v3 is good to test.
BB
