cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
No inicia switch sf302-08p solo aparece SF302-08P-E
arturoharr
Alguien que me pueda ayudar el swicht creo yo que esta muerto y no se como restaurarlo solo me aparece esto
SF302-08P-E> ?
# MFG code v1.10L ; Boot v1.1.0.6 ; Runtime v1.1.2.0 , checksum= 0x3157DB3E
0. Test items [ item 3, 4, A, G ]
1. Board ID test
2. System LED and port LED test [ Not automatic. Need tester to check. ]
3. DRAM test [ Spend 1.5 minutes ]
4. Read all copper phy vendor ID
5. Power down all copper phy
6. Power up all copper phy
7. Reset all copper phy and restart auto negotiation
8. Change all copper gigabit phy transmitter type to class A or class B
9. Copper internal and external loopback test
A. Search PoE Device via I2C
B. Enable PoE function and get per port status
C. Disable PoE function and set port priority or type [ Debug Mode ]
D. Search SFP Device via I2C
E. Gigabit phy on green ethernet mode [ Half poewer : cable length < 40M ]
F. Change combo ports to fiber mode, check SFP status, external loopback test
G. Simple or full flash test [ One loop full test spends 5 minutes ]
H. Ping test [ Ping 192.168.1.140 ]
P. Reset button test [ You only have ten seconds to press reset button ]
# DUT is SF302-08P-E[SRW208P] 16M_Flash 128M_RAM 8FE+2G_Combo PoE 62W
SF302-08P-E>
0 RESPUESTAS 0
