cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
45
Respuestas
SW_MATM-4-MACFLAP_NOTIF flapping between port Gi1/0/21 and port Gi1/0/
matias-silva
I am experiencing flap issues on my Cisco 9300 devices. These are connected to 9200 access switches, creating redundancy with two core switches (9300). The access switches have two uplink ports, one connected to each core switch. I have reviewed the spanning-tree, port-channel, and trunk configurations and have not detected any inconsistencies. All devices are provisioned in DNA Center.
When executing a show mac address for the MAC, it is observed that it oscillates between ports 21 and 22. I also checked for multiple MAC addresses on an access port to identify any out-of-standard switches, but nothing was found. No physical loop was detected either.
witch Ports Model SW Version SW Image Mode
* 1 52 C9200L-48P-4X 17.09.04a CAT9K_LITE_IOSXE INSTALL
cm_tr_p2c_cabecera1_9300#sh etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(SU) PAgP Gi1/0/23(P) Gi1/0/24(P)
cm_tr_p2c_cabecera1_9300# sh int trunk
Port Mode Encapsulation Status Native vlan
Gi1/0/20 on 802.1q trunking 1
Gi1/0/21 on 802.1q trunking 1
Gi1/0/22 on 802.1q trunking 1
Te1/1/1 on 802.1q trunking 1
Po1 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi1/0/20 19,32,126,132
Gi1/0/21 19,32,126,132
Gi1/0/22 19,32,126,132
Te1/1/1 310,320
Po1 19,32,126,132
Port Vlans allowed and active in management domain
Te1/1/1 310,320
Po1 19,32,126,132
Port Vlans in spanning tree forwarding state and not pruned
Te1/1/1 310,320
Po1 19,32,126,132
cm_tr_p2c_cabecera1_9300# sh vl br
VLAN Name Status Ports
1 default active Gi1/0/1, Gi1/0/2, Gi1/0/3, Gi1/0/4, Gi1/0/5, Gi1/0/6, Gi1/0/7, Gi1/0/8, Gi1/0/9, Gi1/0/10, Gi1/0/11, Gi1/0/12
Gi1/0/13, Gi1/0/14, Gi1/0/15, Gi1/0/16, Gi1/0/17, Gi1/0/18, Gi1/0/19, Te1/1/2, Te1/1/3, Te1/1/4, Te1/1/5
Te1/1/6, Te1/1/7, Te1/1/8, Ap1/0/1
19 Admin_y_Ospf active
32 Lan1 active
126 telefonia active
132 ToIP_P2C active
310 WAN_DATOS active
320 WAN_VOZ active
400 VLAN0400 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
cm_tr_p2c_cabecera1_9300# sh mac add ad c85a.cfa6.c721
Mac Address Table
Vlan Mac Address Type Ports
32 c85a.cfa6.c721 DYNAMIC Gi1/0/22
Total Mac Addresses for this criterion: 1
Mac Address Table
32 c85a.cfa6.c721 DYNAMIC Gi1/0/21
45 RESPUESTAS 45
M02@rt37
Hello @matias-silva
On 2 C9300 do that command and share output please:
show spanning-tree vlan 32
Best regards
I am attaching the commands on both C9300
cm_tr_p2c_cabecera1_9300#show spanning-tree vlan 32
VLAN0032
Spanning tree enabled protocol rstp
Root ID Priority 32
Address c47e.e094.5e00
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32 (priority 0 sys-id-ext 32)
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Gi1/0/20 Desg FWD 20000 128.20 P2p
Gi1/0/21 Desg FWD 20000 128.21 P2p
Gi1/0/22 Desg FWD 20000 128.22 P2p
Po1 Desg FWD 10000 128.3049 P2p
cm_tr_p2c_cabecera2_9300#show spanning-tree vlan 32
VLAN0032
Root ID Priority 32
Cost 10000
Port 3049 (Port-channel1)
Bridge ID Priority 4128 (priority 4096 sys-id-ext 32)
Address c47e.e078.5380
Aging Time 300 sec
Gi1/0/20 Desg FWD 15 128.20 P2p
Gi1/0/21 Desg FWD 15 128.21 P2p
Gi1/0/22 Desg FWD 15 128.22 P2p
Po1 Root FWD 10000 128.3049 P2p
If mac flapping between g1/0/20  and any port member of PO then issue in your PO and/or  native vlan issue
MHM
It oscillates between the trunk links that go directly to the access switches, it does not oscillate within the port-channel. I have two C9300 core switches and three C9200 access switches. The C9200 have two uplinks, one connection to each C9300.
There are three points to check
1- are one of port os running netflow or any monitor?
2- did you check native vlan in all your network?
3- loop that worse case
MHM
 Yes, we recently implemented some configurations, I’m attaching the details
Yes, it is only being used on UP ports that have no configuration and nothing connected.
There are no records of loops.
We recently implemented the following configurations
Cdp run
Lldp run
device-sensor filter-list dhcp list DHCP_SENSOR
option name host-name
option name client-identifier
option name client-fqdn
option name class-identifier
option name parameter-request-list
device-sensor filter-spec dhcp include list DHCP_SENSOR
device-sensor filter-list lldp list LLDP_SENSOR
tlv name system-description
tlv name port-id
tlv name system-name
tlv name system-capabilities
device-sensor filter-spec lldp include list LLDP_SENSOR
device-sensor filter-list cdp list CDP_SENSOR
tlv name device-name
tlv name capabilities-type
tlv name platform-type
tlv name version-type
device-sensor filter-spec cdp include list CDP_SENSOR
device-sensor notify all-changes
device-tracking tracking auto-source
device-tracking policy IPDT_POLICY
tracking enable
interface GigabitEthernetX/X/X (puertas de acceso)
device-tracking attach-policy IPDT_POLICY
radius-server attribute 6 on-for-login-auth
radius-server attribute 6 support-multiple
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server attribute 31 mac format ietf upper-case
radius-server attribute 31 send nas-port-detail mac-only
mac address-table notification change
mac address-table notification mac-move
epm logging
radius-server vsa send accounting
radius-server vsa send authentication
template MAB
dot1x timeout tx-period 10
dot1x timeout supp-timeout 10
flow record SW_FLOW_RECORD
description NetFlow to CTB-BECH
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect transport tcp flags
collect interface output
collect counter bytes long
collect counter packets long
collect timestamp absolute first
collect timestamp absolute last
flow exporter NETFLOW_TO_CTB
description Export NetFlow to CTB-BECH
destination 172.16.xx.xx
source Vlan19
transport udp 2055
template data timeout 30
option interface-table
option application-table timeout 10
flow monitor IPv4_NETFLOW
cache timeout active 60
cache timeout inactive 15
interface Gig1/0/1
ip flow monitor IPv4_NETFLOW input
!Repite para cada puerto de acceso según sea necesario.
Int vlan x ( VLAN CON DHCP)
Ip helper-address 172.16.xx.xx
Sorry I was out
Now
Share show spanning tree interface <interface that mac flapping between> detail
MHM
Don't worry, I'll share the command from the C9300s. Please note that the flap log is only visible on a C9300 (Cabecera1) and not on the C9200 switches.
cm_tr_p2c_cabecera1_9300#sh spanning-tree int Gi1/0/20
Vlan Role Sts Cost Prio.Nbr Type
VLAN0019 Desg FWD 20000 128.20 P2p
VLAN0032 Desg FWD 20000 128.20 P2p
VLAN0126 Desg FWD 20000 128.20 P2p
VLAN0132 Desg FWD 20000 128.20 P2p
cm_tr_p2c_cabecera1_9300#sh spanning-tree int Gi1/0/21
VLAN0019 Desg FWD 20000 128.21 P2p
VLAN0032 Desg FWD 20000 128.21 P2p
VLAN0126 Desg FWD 20000 128.21 P2p
VLAN0132 Desg FWD 20000 128.21 P2p
cm_tr_p2c_cabecera1_9300#sh spanning-tree int Gi1/0/22
VLAN0019 Desg FWD 20000 128.22 P2p
VLAN0032 Desg FWD 20000 128.22 P2p
VLAN0126 Desg FWD 20000 128.22 P2p
VLAN0132 Desg FWD 20000 128.22 P2p
cm_tr_p2c_cabecera2_9300#sh spanning-tree int Gi1/0/20
VLAN0019 Desg FWD 15 128.20 P2p
VLAN0032 Desg FWD 15 128.20 P2p
VLAN0126 Desg FWD 15 128.20 P2p
cm_tr_p2c_cabecera2_9300#sh spanning-tree int Gi1/0/21
VLAN0019 Desg FWD 15 128.21 P2p
VLAN0032 Desg FWD 15 128.21 P2p
VLAN0126 Desg FWD 15 128.21 P2p
cm_tr_p2c_cabecera2_9300#sh spanning-tree int Gi1/0/22
VLAN0019 Desg FWD 15 128.22 P2p
VLAN0032 Desg FWD 15 128.22 P2p
VLAN0126 Desg FWD 15 128.22 P2p
VLAN0132 Desg FWD 15 128.22 P2p
Detail <<- in end of command and share output
MHM
Ok, I'm sharing the details with you.
cm_tr_p2c_cabecera1_9300#sh spanning-tree int Gi1/0/22 de
Port 22 (GigabitEthernet1/0/22) of VLAN0019 is designated forwarding
Port path cost 20000, Port priority 128, Port Identifier 128.22.
Designated root has priority 19, address c47e.e094.5e00
Designated bridge has priority 19, address c47e.e094.5e00
Designated port id is 128.22, designated path cost 0
Timers: message age 0, forward delay 0, hold 0
Number of transitions to forwarding state: 1
Link type is point-to-point by default
BPDU: sent 2532723, received 10
Port 22 (GigabitEthernet1/0/22) of VLAN0032 is designated forwarding
Designated root has priority 32, address c47e.e094.5e00
Designated bridge has priority 32, address c47e.e094.5e00
BPDU: sent 2532723, received 9
Port 22 (GigabitEthernet1/0/22) of VLAN0126 is designated forwarding
Designated root has priority 126, address c47e.e094.5e00
Designated bridge has priority 126, address c47e.e094.5e00
BPDU: sent 2532722, received 0
Port 22 (GigabitEthernet1/0/22) of VLAN0132 is designated forwarding
Designated root has priority 132, address c47e.e094.5e00
Designated bridge has priority 132, address c47e.e094.5e00
cm_tr_p2c_cabecera1_9300#sh spanning-tree int Gi1/0/20 de
Port 20 (GigabitEthernet1/0/20) of VLAN0019 is designated forwarding
Port path cost 20000, Port priority 128, Port Identifier 128.20.
Designated port id is 128.20, designated path cost 0
BPDU: sent 2532728, received 13
Port 20 (GigabitEthernet1/0/20) of VLAN0032 is designated forwarding
Port 20 (GigabitEthernet1/0/20) of VLAN0126 is designated forwarding
BPDU: sent 2532728, received 0
Port 20 (GigabitEthernet1/0/20) of VLAN0132 is designated forwarding
cm_tr_p2c_cabecera1_9300#sh spanning-tree int Gi1/0/21 de
Port 21 (GigabitEthernet1/0/21) of VLAN0019 is designated forwarding
Port path cost 20000, Port priority 128, Port Identifier 128.21.
Designated port id is 128.21, designated path cost 0
BPDU: sent 2532732, received 9
Port 21 (GigabitEthernet1/0/21) of VLAN0032 is designated forwarding
Port 21 (GigabitEthernet1/0/21) of VLAN0126 is designated forwarding
BPDU: sent 2532731, received 0
Port 21 (GigabitEthernet1/0/21) of VLAN0132 is designated forwarding
cm_tr_p2c_cabecera2_9300#sh spanning-tree int Gi1/0/20 de
Port path cost 15, Port priority 128, Port Identifier 128.20.
Designated bridge has priority 4115, address c47e.e078.5380
Designated port id is 128.20, designated path cost 10000
Number of transitions to forwarding state: 3
BPDU: sent 2532765, received 14
Designated bridge has priority 4128, address c47e.e078.5380
BPDU: sent 2532763, received 14
Designated bridge has priority 4222, address c47e.e078.5380
BPDU: sent 2532759, received 0
Designated bridge has priority 4228, address c47e.e078.5380
BPDU: sent 2532759, received 14
cm_tr_p2c_cabecera2_9300#sh spanning-tree int Gi1/0/21 de
Port path cost 15, Port priority 128, Port Identifier 128.21.
Designated port id is 128.21, designated path cost 10000
BPDU: sent 2532763, received 12
BPDU: sent 2532761, received 0
cm_tr_p2c_cabecera2_9300#sh spanning-tree int Gi1/0/22 de
Port path cost 15, Port priority 128, Port Identifier 128.22.
Designated port id is 128.22, designated path cost 10000
BPDU: sent 2532765, received 11
BPDU: sent 2532763, received 13
BPDU: sent 2532762, received 0
Number of transitions to forwarding state: 4
BPDU: sent 2532768, received 14
VLAN 126 the SW is 0 received any bpdu
And port g1/0/22 or 21 are trunk
So there is issue with vlan 126.
Vlan 32 and 126 is native vlan in any SW?
Check STP of vlan 126 if you use RSTP
If you use different mode of STP please inform me which mode ypu use
MHM
VLAN 126 was not in use and had no configuration, so we removed it at both layer 2 and layer 3. VLAN 32 is the data VLAN for the access ports on each switch.
Despite having removed the VLAN from the configurations, the flapping persists on the cabecera 1 (C9300)
I have another network with the same configurations, and it works correctly. The only difference is that on those switches, the version is 17.06.04, and on the ones with the flapping issue, the version is 17.09.04a. Could there be a bug in C9200?
BPDU: sent 2532762, received 0 <<<- run same command of show spanning tree interface detail and check this count is it increase or still same
Also make double check
Vlan 32 is native vlan in any trunk
Vlan 126 is totally remove from SW
Any SW run old STP mode or MST not PVST
MHM
